Old 01-17-2007, 06:26 PM   #1 (permalink)
AznSupastar's Avatar
2007 Taffeta White Si Coupe
beware! clutch pedal must be replaced as a whole
so recently, the rubber stops on the Si's clutch pedal fell off. naturally, i went to get it fixed (2 month old car) and they ordered me the rubber layer for the whole clutch steping area. then next day when i bring in the car, it took them 2 hrs to work on the car. i think to myself, it doens't think a genius to unscrew the 3 screws, swap the new rubber layer in and screw it back on. WHAT IS GOING ON? turns out u CAN'T unscrew the screws, u can't replace the rubber layer, U HAVE TO REPLACE THE WHOLE FREAKING CLUTCH with the stem! i have yet gone in the get it replaced, i'm afraid it's a BIG job and they would need to unmount all my coverings.... anyone a mechanic? is it a big job to replace the clutch pedal with the stem?
if this doesn't make count, post here and i try to explain myself better.
AznSupastar is offline   Reply With Quote
Old 01-17-2007, 06:54 PM   #2 (permalink)
xmx250's Avatar
Are you kidding!!! We have to replace the entire clutch pedal and stem to change the worn rubber? If this is accurate someone at honda engineering needs to be slapped.
xmx250 is offline   Reply With Quote
Old 01-17-2007, 07:21 PM   #3 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
I'm a bit confused as to which part was replaced. Can you point it out on the following diagram (part #)?
Old 01-17-2007, 07:27 PM   #4 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
#27 is the SI clutch pedal pad.If there's a number on it you should be able to buy it.
Is that from a parts catalogue 8thgenuser?
NBPRudy is offline   Reply With Quote
Old 01-17-2007, 07:51 PM   #5 (permalink)
Webby's Minion
8thgenuser's Avatar
Yes, it's from an online parts catalog. Most OEM online parts dealers will have a picture on their site. This particular one is from hondapartsdeals.com.
Old 01-17-2007, 08:04 PM   #6 (permalink)
CivicDude's Avatar
also looking at the picture above it seems to be riveted on. So the old rivet needs to be drilled out and the new one put in.
Doesnt seem too complicated. Doesnt seem as though replacing the whole pedal mechanism would be cost efficient.
CivicDude is offline   Reply With Quote
Old 01-17-2007, 11:10 PM   #7 (permalink)
Are they saying this is a warranty repair?
If not they are just ripping you off.
Or the mechanics/service manager are trying to make some money off the dealership.
bioevolve is offline   Reply With Quote
Old 01-17-2007, 11:20 PM   #8 (permalink)
articsilber323's Avatar
i hope that my dealer will replace mine with no problem when mine get worn out
articsilber323 is offline   Reply With Quote
Old 01-18-2007, 12:07 AM   #9 (permalink)
yes, i'm referring to part #27, although u can get the parts. u CAN'T install them cuz u CAN'T unscrew the screws that hole the metal plate, rubber, and the clutch pedal. took my dealer 1hr to TRY to drill it out. so now they going to replace the ENTIRE clutch pedal with the long stem.
yes this is warranty, and i'm gong to make sure they do a good job at it. update u guys later
Old 01-18-2007, 01:18 AM   #10 (permalink)
2RotorMotor's Avatar
The clutch pedal assy. is actually very easy to remove. There are like 3 bolts that you need to losen completely + a guide bolt(#22). And the assy. can be removed completely. Be AWARE that by removing the bolts for the pedal assy. you also free the clutch master cylinder. In other words, the removal of the pedal assy is the same as if you were removing the CMC..
2RotorMotor is offline   Reply With Quote
Old 01-18-2007, 09:50 AM   #11 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
After doing a little research on this I found instructions on how to remove and install a new brake pedal pad but when checking the clutch pad it says to replace the whole clutch pedal which really doesn't make any sense but it seems to be what they need to do.
Old 01-18-2007, 09:56 AM   #12 (permalink)
BATANG CITY JAIL's Avatar
a speacial tool is needed to unscrew the pedal pad....
Old 01-18-2007, 09:58 AM   #13 (permalink)
to charge you double for thier job...
if ever they replace the whole clutch pedal assembly, make sure to get the part that they take out... they cant say no since you pay for the whole thing...
Old 01-18-2007, 10:02 AM   #14 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
Yeah but it's warranty so it doesn't matter in this case.If anyone is noticing the same problem get warranty to fix it while you still have it.
Old 01-18-2007, 10:05 AM   #15 (permalink)
there is a warranty for on the rubber?
Old 01-18-2007, 10:10 AM   #16 (permalink)
yup, lol. at least 4 me. i would much prefer them to unscrew the rivets since u guys say it's doable. save me the time and risk of them screwing up other parts when they install the entire clutch. blahhhhhhh
Old 01-18-2007, 10:18 AM   #17 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
In Canada anyway it's a 3yr 60000km warranty.
Old 01-18-2007, 10:28 AM   #18 (permalink)
oh i don't know that...
Old 05-10-2007, 06:55 AM   #19 (permalink)
8thcivic Sponsor
strutking's Avatar
We offer the rubber piece separately for $6 shipped and $10 for the pair. Our rubber inserts will fit the Si pedals, however you will need to rerivet them onto your pedals.
FREE Shipping within the US!
10% off coupon code: 8thcivic
Want to win a 3G iPhone? visit our website for more details!
strutking is offline   Reply With Quote
Clutch pedal squeaking TJ06CivicLX Mechanical Problems & Technical Chat 23 09-29-2008 03:26 PM
Vibration in clutch pedal? SonicK20Z Mechanical Problems & Technical Chat 9 09-10-2007 12:04 AM
Clutch pedal. Spinning Noise??? muxtang67 Mechanical Problems & Technical Chat 7 10-06-2006 11:28 PM
creaky clutch pedal BLU BY U Mechanical Problems & Technical Chat 9 08-31-2006 10:08 PM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 08:34 AM
