Strange noise around 2.5k
2006 LX Sedan.
The 2.4k - 2.6k range seems to be the magic #. It doesn't matter what gear I'm in. As soon as I approach it my car starts making an electric-sounding noise. It's hard to explain...kind of like the noise a transformer makes when you walk past it? Or that high-pitched noise you sometimes hear on TVs when they're on? Don't know...I'm afraid that's the best I can do as far as describing it. If I turn the radio up pretty loud I can drown it out, but at normal volumes the noise can still be heard over it. Anyway, the noise has been happening for a long time, but it used to be random. Now it seems to be settling down into a fairly consistent pattern. It doesn't happen every time I drive, but I'd say around 75% of the time. When I take the car out, it's either happening every time or not at all. Any ideas? |
I would bring it into the dealership and have it documented immediately. Even if they don't find anything, a report has been documented and you may be able to refer back to it if anything were to happen in the future.
Anywho, there have been some reports (more or less with the Si) regarding a little whining noise or engine noise at certain RPMs, but my '06 LX sedan doesn't do that. |
#3 (permalink) | |
The problem, of course, is that I can't really be without my car for any extended period of time thanks to work. |
Are you sure this isnt the timing chain. Timing chains make a wurr and whistle is they arent lubricated correctly.
A proper lubricated timing chain should make no noise or a slight whine. The dealership definitely wont wanna pull the engine. Keep taking it back and documenting it. |
#8 (permalink) | |
| Strut noise from lowering... | Biggeo | Mechanical Problems & Technical Chat | 3 | 11-03-2006 11:23 AM |
| Strange trans noise | badkarma | Mechanical Problems & Technical Chat | 12 | 11-02-2006 01:00 PM |
| Spinning noise gradually increasing as RPM goes up | joonoo | Mechanical Problems & Technical Chat | 0 | 09-03-2006 02:54 AM |
| Creaking noise from the back of the car. help! | Spyder24 | Mechanical Problems & Technical Chat | 13 | 07-20-2006 12:17 AM |
| Strange chirping noise... | Skyline | Mechanical Problems & Technical Chat | 3 | 05-30-2006 01:50 PM |
