Old 01-15-2007, 09:38 PM   #1 (permalink)
SacrificeTheory's Avatar
Chris
Squeaky Clutch?
I got my Civic Si in November. It has a little under 3,600miles on the car. However, whenever I slowly let go of the clutch, you hear it squeaking like a door that needs oil. I've never smelled my clutch burning, so it can't be needing a change already, can it?
SacrificeTheory is online now   Reply With Quote
Old 01-15-2007, 09:56 PM   #2 (permalink)
Shark Tek's Avatar
I have the same problem but you must check it because at least for me the sound is coming from the pedal not from the clutch.
I bet that a few drops of a lubricant on the joints of the clutch pedal below the dash, the problem will be solved.
Shark Tek is offline   Reply With Quote
Old 01-15-2007, 10:04 PM   #3 (permalink)
BLU BY U's Avatar
had the same problem, went away completely though.
Old 01-15-2007, 10:12 PM   #4 (permalink)
Chris
So it's normal then? I shouldn't need another clutch already, right?
Old 01-15-2007, 10:15 PM   #5 (permalink)
BLU BY U's Avatar
no need for a clutch bro, does it only do it whens its wet out?
Old 01-15-2007, 10:23 PM   #6 (permalink)
Chris
Actually, it happened just recently. It's been raining for the last three days.
Old 01-15-2007, 10:25 PM   #7 (permalink)
BLU BY U's Avatar
apparently it has to do with something getting wet, it hasnt happened to me though. maybe some bushing needs to get wet a few times until it stops doing it?
Old 01-15-2007, 10:42 PM   #8 (permalink)
MutantCheese's Avatar
2008 NFR S2000
Mine just started squeaking this past week. It's def the pedal, not the clutch. If it keeps up, i'll lube it.
MutantCheese is offline   Reply With Quote
Old 01-15-2007, 10:46 PM   #9 (permalink)
Chris
Has it been raining a lot lately around your area too?
Old 01-15-2007, 10:54 PM   #10 (permalink)
2008 NFR S2000
yes, definitely not dry here.
Old 01-15-2007, 10:57 PM   #11 (permalink)
Chris
I guess our cars dont like the rain
Old 01-16-2007, 07:30 AM   #12 (permalink)
BLU BY U's Avatar
give it a couple weeks. then update us.
Old 01-20-2007, 11:21 AM   #13 (permalink)
Chris
It seems to be gone now. Haven't heard it in a couple of days.
Old 01-20-2007, 11:22 AM   #14 (permalink)
2008 NFR S2000
mine stopped as well. @ about 2300 miles.
Old 01-20-2007, 02:28 PM   #15 (permalink)
SiRyan's Avatar
Mine squeeks when its not at operating temp.
SiRyan is offline   Reply With Quote
Old 06-03-2008, 04:14 PM   #16 (permalink)
Cbeyer2's Avatar
Chris Beyer
revival of dead thread.... My clutch is redic... and I asked about it when I was at the dealer and one of the techs said his did it too and therefore it was fine... ugh lol... how are all of yall squeaks? gone? any of you lube it up? because I'm really about to try as it is pissin me off..
Cbeyer2 is offline   Reply With Quote
Old 06-03-2008, 04:21 PM   #17 (permalink)
I can smell the grave this thread just got out of
Noticed that all of these posts have something to do with a squeaky Si clutch pedal while it's been raining out.
Just my opinion on the matter: I don't think it's your clutch at all, but rather the wet rubber of the shoe sole grinding against the now wet rubber studs of the Si pedal. Eh, just my thoughts.
gx4th is offline   Reply With Quote
Old 06-03-2008, 04:24 PM   #18 (permalink)
Cbeyer2's Avatar
Chris Beyer
yea, I thought that too, but its not, as it happens barefoot lol. There def is some correlation to the rain which is weird cuz its a sound from the inside i think, but I'm pretty sure that its just the pedal so i really dunno. I wouldn't really have any idea what are safe lubes and where to put them. I don't want to screw anything up.
Old 06-03-2008, 04:30 PM   #19 (permalink)
Leonard1818's Avatar
Leonard
My RSX-S clutch pedal used to squeak. It was the pushrod that went thru the firewall. Get some silicone spray lubricant and find the point this goes thru. Hit it like hell with this spray lube. Push the clutch in and out several times to work the lube in a bit. Report back ASAP.
Leonard1818 is offline   Reply With Quote
Old 06-03-2008, 04:33 PM   #20 (permalink)
Cbeyer2's Avatar
Chris Beyer
That is def a possibility, I'ma go git some right now before work. but wont be able to say how it went till I get back. Wow, I really brought this thread back....guess lots of other people still have this prob. Thanks for the help!
PICS! clutch vicSi Mechanical Problems & Technical Chat 11 05-08-2007 05:29 AM
Squeaky clutch? bung_goo Civic SI 17 03-07-2007 01:19 PM
Clutch make squeaky sound from outside Kenbeal Mechanical Problems & Technical Chat 6 12-01-2006 12:19 PM
Clutch vibrates mellowbob Mechanical Problems & Technical Chat 0 09-15-2006 04:48 PM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 08:34 AM
