t('.'t )
door sill loose
took my car to an audio shop to get my system hooked up.
they ran the power through the door sill but now its mis-aligned. i was hoping there would be an easy way to fix this but everytime i go to pop it back in place it snaps out and when i close the door i can hear it grinding against the door. here's some pics: ![]() ![]() ![]() ![]() it seemes as though theres some blue residue on that little white piece and i was wondering if maybe it was glued down and maybe i should re glue it? any one run power that route? what did you guys end up doing? edit: damn my interior is dirty..
06 FG1 LX MT ![]() AEM CAI | Magnaflow Cat-Back | Comptech SS | TWM Bushings | Eibach Prokit | Enkei Evo 6 |
I wonder if they damaged the clips to the point they don't have the power to hold down the trim piece?
It's also possible the cable they ran under the trim is to thick to let the trim sit flush the way it should. I don't trust most installers, they don't take care of your car like you would. |
the wire looks like it's in the way so that's y it doesn't clip down properly....there no glue on those clips and they don't look broken....i would say just try and move the wire so it's not in the way.....maybe under the carpet....and u should be fine after that
Rene....
Take it back asap to audio shop that worked on the car. They are 100% liable for the damage done to the car,let them figure out why the trim piece keeps on coming out,its their responsibility, not yours.
ps.Here is a pick of all the clips on the door sill(6 of them)
| Changing my r18 grill to an si will i loose warrnty | lightlypurified | Garage | 4 | 09-10-2006 06:13 PM |
| Will I Loose My Security If I Install An Aftermarket Navi? | 1919beerman | I.C.E., Electrical, Security, & Navigation | 4 | 08-28-2006 09:09 AM |
| window is loose when is roll half way down while you shut the door..it rattle losse?? | irichard | Mechanical Problems & Technical Chat | 13 | 05-04-2006 03:53 PM |
| loose gas pedal? | LsedanX | Mechanical Problems & Technical Chat | 3 | 04-20-2006 10:00 PM |
