WooooHooooo
what coolant/anti-freeze to use?
just found out i'm low on coolant.
is it ok to use a different brand of coolant/anti-freeze and mix it w/ the one i have right now from honda? thanks...
![]() The last time I was inside a woman was when I went to the Statue of Liberty ![]() |
#4 (permalink) | |
#5 (permalink) | |
Rene....
How did you found out you are low on coolant? |
#7 (permalink) | |
Rene....
Only a small amount of fluid is lost when you disconnect the throttle body coolant hose. I have replaced my intake 3 times already,and I have yet to top of my coolant. |
You can look at your coolant overflow, which is the reservoir next to battery.
Or when engine is cold, open the radiator cap and look inside with a flashlight. Do our cars use normal green antifreeze or one of those other colored long life antifreeze? |
#10 (permalink) | |
our cars actually use BLUE antifreeze. i thought when i picked up the car new that someone put windshield washer fluid in there! the green prestone 50/50 mix will be fine if you can't pick up honda's stuff. |
#11 (permalink) | |
just to be on the safe side, just go to the honda dealer and spend the extra 3 or 4 bucks on honda genuine coolant. |
#12 (permalink) | |
also, lets say you do drive and check and it's still low, it could be that it's so cold that the thermostat hasn't "opened up" to release the coolant (but this is only in extremely cold weather). |
#13 (permalink) | |
Source I hope the Honda brand isnt dexron based
#15 (permalink) |
I would only personally use Honda antifreeze as Honda's have very finicky cooling systems with TINY coolant passages. You paid at least $15K+ for your car, don't cheap out on $5 on your coolant. I do know if u use the standard Prestone the silicates will slowly destroy the water pump and seals. Also Dex-cool IS NOT the same as Honda's formulation. I believe they also use OATS as corrosion inhibitors similar to Dex-cool, but there's some several key differences. Dex-cool btw has been implicated in causing solids to form in the coolant if you let the reservoir run dry and introduce air into the system. I read all this in some ASE magazine for mechanics somewhere while I was having my 93 civic worked on at an independent honda mechanic.
#16 (permalink) |
Here's a link on OAT coolants:
Universal Coolant: The Ultimate Antifreeze? |
