Old 01-09-2007, 11:48 PM   #1 (permalink)
hiphopaddict's Avatar
Kevin Williams
Question Any way to check the transmission fluid?
Is there a way to check the transmission fluid level on an Si? A dip-stick perhaps? I'd like to see if it's been overfilled at the factory.
hiphopaddict is offline   Reply With Quote
Old 01-09-2007, 11:54 PM   #2 (permalink)
udumkid's Avatar
Rene....
use your finger as a dipstick.
1)loosen FILL plug.
2)insert finger into the fill hole to check fluid level. If tranny is over full the fluid would just come out of the fill hole
udumkid is offline   Reply With Quote
Old 01-10-2007, 10:19 AM   #3 (permalink)
NIGHTHAWKSI's Avatar
Ian
my MTF was very overfilled. when ichanged the flud it was pouring out. it wouldnt suprise me if it was half a quart too full.
Old 01-10-2007, 10:20 AM   #4 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
^^ I wonder why?
GeezerSi is online now   Reply With Quote
Old 01-10-2007, 11:01 AM   #5 (permalink)
Ian
Originally Posted by GeezerSi
^^ I wonder why?
it must have came like that from the factory
Old 01-10-2007, 12:34 PM   #6 (permalink)
truflip's Avatar
i heard changing the factory MTF makes shifting better and more fun.. even Honda says theyre new tranny fluid is better... and i read somewhere some Honda techs recommend GM's tranny fluid
truflip is offline   Reply With Quote
Old 01-10-2007, 12:56 PM   #7 (permalink)
Nacho Cheese!
letsgoflyers81's Avatar
I've read that many people have found their transmissions were overfilled from the factory. With too much pressure, that causes some of the transmissions issues we've seen, even if you don't take the supposedly poor quality of Honda's MTF. Plenty of people have seen an improvement of just replacing their MTF with stock Honda MTF and using the correct amount. That said, I just ordered some Amsoil to see how that helps the 3rd gear problems I'm having.
letsgoflyers81 is offline   Reply With Quote
Old 01-10-2007, 08:23 PM   #8 (permalink)
articsilber323's Avatar
i just changed my MTF to amsoil syncromesh 5W-30 and it has been great
mine was also overfuiled by .3 quarts
i am so glad that i changed this out
best 20 dollars i have spent!!!
articsilber323 is offline   Reply With Quote
Old 01-15-2007, 06:18 PM   #9 (permalink)
Just put in amsoil after twm bushings and short shifter package. Guess what?....they overfilled the damn thing from the factory. Tranny oil came gushing out for some time. Nut heads.
vetkiller is offline   Reply With Quote
DIY: Changing Manual Transmission Fluid BATANG CITY JAIL Transmission 398 11-19-2008 09:38 PM
Manual Transmission Fluid FusionSi11 Mechanical Problems & Technical Chat 40 01-18-2007 03:14 PM
Transmission fluid change results ADewan Mechanical Problems & Technical Chat 0 12-04-2006 10:23 PM
First oil change/trans fluid change BEFORE 3500 miles? djdefcon Civic SI 7 08-22-2006 09:36 AM
Too Early for Tranny Flush?? taste Do It Yourself Articles 12 06-23-2006 08:55 PM
