Old 01-08-2007, 03:47 PM   #1 (permalink)
Drivers side window problems
This started a couple of weeks ago with no warning....
The driver side window on my 06 EX sedan has started to jam on auto up (close). The window closes normally (on auto up) until it reaches about 3/4 closed. The window then seems to "stick" at the front corner, causing it to tilt in the track (gap appears on the back side of the window) and stop.
I check for obstructions in the visible area of the track, there are none. The window doesn't seem to have any more play in it than the passenger side does. My initial thought was that it jumped off track. I did try to lube the track from above with a shot of silicone spray, which fixed it for about a day. I cleaned the edge of the window, to rule out something sticky on the glass causing it to stop in the track.
At this point I am ready to take it in for service, however, the dang thing started to work fine today. Although you can hear it strain slightly (like it is stuck) when you lower the window (it didn't do this before the problems).
Anyone here had an issue like this? I was playing with the idea of taking off the interior panel to have a look at the track, but am still leaning towards making this a dealer problem. Just thought I would ask here before I wasted an entire day at the dealership.
Since it seems to work today, I would suspect that there is either...
1. something in the track causing an obstruction
2. something loose in the track/window assembly that causes an intermittent failure.
bskouby is offline   Reply With Quote
Old 03-18-2007, 11:37 AM   #2 (permalink)
rivas240sx's Avatar
Christian
I've had the same problem. It seems to only happen on hot days, so my first guess is the rubber gets hot and makes it harder to go up and then retracts thinking there is an obstruction. But there seems to be too much play on the window so I might take it in to get it looked at.
rivas240sx is offline   Reply With Quote
Old 03-18-2007, 12:04 PM   #3 (permalink)
SiCali's Avatar
it could be the motor as well. did you look at the condition of the teeth on the track? they can wear down over time, especially if you're moving your window while on the freeway.
SiCali is offline   Reply With Quote
Old 04-02-2007, 05:38 PM   #4 (permalink)
rivas240sx's Avatar
Christian
Car has 6k on it, could it had worn that fast? Its getting worse now, it looks like its catching the interior window seal. I'm definively taking it in now.
Old 04-02-2007, 11:56 PM   #5 (permalink)
ABM JDM's Avatar
JDABM fan
^^^ Let us know how that goes.
Crap, this just happened to me for the first time today... very odd, don't know what to make of it. And I only have 4k on mine.
ABM JDM is offline   Reply With Quote
Old 04-03-2007, 08:33 AM   #6 (permalink)
moxom's Avatar
Take it to the shop.
moxom is offline   Reply With Quote
Old 04-03-2007, 10:37 PM   #7 (permalink)
mine did that (06 with about 5K at the time) got a little better, then a few weeks later at an automated parking lot the glass just feel into the door.
Go to the dealer and get them to fix it ASAP
jpto is offline   Reply With Quote
Old 04-03-2007, 11:49 PM   #8 (permalink)
F-1 Si's Avatar
Peter
I had that prob with my 07 FA5. I called the dealer about it and they ordered new window tracks and replaced them 2 days later no questions asked.
F-1 Si is offline   Reply With Quote
Old 04-24-2007, 11:01 PM   #9 (permalink)
rivas240sx's Avatar
Christian
Dealer says its the actuator, and the track got worn off because the window was going off track. Covered under warranty
Old 04-25-2007, 12:43 AM   #10 (permalink)
Mine did this too, the dealer replaced the window tracks under warranty. no problems since.
scrappy is offline   Reply With Quote
U.S. & Canadian Tint Laws jc21 Inside and Out 42 11-24-2008 05:46 PM
AutoX 101 brooklynscat69 Autocross & Sanctioned Drag Racing 21 01-11-2008 09:22 PM
driver's side airbag indicator waterboi Mechanical Problems & Technical Chat 2 05-09-2006 12:57 AM
Mirrors and Side Window mcpaige Civic SI 15 02-17-2006 01:28 PM
