DIY ** NST Civic SI underdrive pulleys - Page 10 - 8th Generation Honda Civic Forum
Closed Thread
Old 06-30-2008, 11:04 AM   #181 (permalink)
pchunggerr's Avatar
Pat Chung
I wish there were pics again.
pchunggerr is offline
Old 07-01-2008, 02:11 AM   #182 (permalink)
Javi-Si's Avatar
Javier
can the pictures be fixed? i cant see them it seems they were maybe deleted.
Javi-Si is offline
Old 07-02-2008, 06:05 PM   #183 (permalink)
SIcBoy's Avatar
jr
i know its been stated already but i cant really look there ten pages of this!!!
but how do i LOOSEN the belt and get it back on.. im have alot of trouble so some info would help. and its a great write up suck i cant see the photos anymore..
so please help
SIcBoy is offline
Old 07-02-2008, 06:13 PM   #184 (permalink)
David
so please help
I used a 14mm box end wrench on the tensioner pulley (black pulley basically just below the idler pulley) and slipped the handle of my floor jack over it for extra leverage and pull towards the front of the car. This releases the tension allowing you to slip the belt off of one of the other pulleys. Then gently release the tensioner pulley. Don't put your fingers between a pulley and the belt when you have force applied to the tensioner pulley bolt because if your wrench slips you could crush your fingers!
OrdnanceMarine is offline
Old 07-02-2008, 07:16 PM   #185 (permalink)
SIcBoy's Avatar
jr
thanks bro...
but now the belt is hella loose.
how do i get it tight, now
the tensioner is being a pain!!!
please help
SIcBoy is offline
Old 07-02-2008, 08:00 PM   #186 (permalink)
David
thanks bro...
please help
If you've replaced all three pulleys and it is lose then you've missed getting the belt routed properly. Make sure it's centered on all pulleys (especially the ribbed ones). I set up the belt on all of the pulleys except for the idler pulley, then pulled the tensioner pulley towards the front of the car and slid the idler pulley with the belt on it over the shaft that holds the idler pulley and threaded the idler pulley bolt in by hand. Then I released the tensioner pulley, tightened the idler pulley bolt and verified the belt was centered correctly on all pulleys.
Old 07-03-2008, 01:08 PM   #187 (permalink)
SIcBoy's Avatar
jr
thanks once again...
yeah i had the belt on the wrong way, but i got it back together
SIcBoy is offline
Old 07-07-2008, 11:22 AM   #188 (permalink)
FLIGL2003's Avatar
Kelley
ya where r the pics :-(
FLIGL2003 is offline
Old 07-18-2008, 01:07 AM   #189 (permalink)
sidecut305's Avatar
FA Crew #81
bump for updated pics pleasssssse
sidecut305 is offline
Old 07-20-2008, 12:09 AM   #190 (permalink)
sidecut305's Avatar
FA Crew #81
Old 07-20-2008, 12:20 AM   #191 (permalink)
07mugencivic's Avatar
ToE kNeE
i love that one pic
07mugencivic is offline
Old 07-20-2008, 04:35 AM   #192 (permalink)
IndyMike's Avatar
http://twitter.com/Indymike73
At least for me I've noticed if I use ImageShack® - Image Hosting that my pics stick around for the most part on forums.
If you have time it would be great to be able to see the pics again as I will be also purchasing the pully kit within the next few months along w/ other mods.
IndyMike is offline
Old 07-21-2008, 09:12 PM   #193 (permalink)
dannyd86's Avatar
Danny
Has anyone noticed that after installing the NST pulleys, that on really HOT days (Miami summers are harsh) when at idle the A/C doesn't cool too well? While driving it cools fine, and if stopped, if I hold the rpms a little higher it cools fine as well.
I am almost positive its because of the pulleys, maybe underdriving the compressor, but just wanted to see if anyone else is experiencing this.
dannyd86 is offline
Old 07-30-2008, 04:00 PM   #194 (permalink)
Nate
^^ I have that problem and i'm stock. I was told that it was normal.
Second thing... would be really nice if these pics were fix is there another thread?
whipsnap is offline
Old 07-30-2008, 04:19 PM   #195 (permalink)
MutantCheese's Avatar
2008 NFR S2000
I posted pics of my install somewhere in this thread.
Also posted here: gnoCIVIC.com
Hope that helps.
MutantCheese is offline
Old 07-30-2008, 04:22 PM   #196 (permalink)
Member # 4524
GlxyGry06Si's Avatar
i will be dynoing these saturday. I dyno'd last time at 206.5 so we shall see what these babies put down. It will be on the same dyno and relitively the same temp. It was 98 last time and its only got hotter. I will keep you guys posted.
Originally Posted by TheIncident88 View Post
Sometimes I actually wonder if you are serious or just ******* with me. If it's the latter, then well played sir. If not, then I shall return my palm to it's previous position upon my face.
GlxyGry06Si is offline
Old 07-30-2008, 04:28 PM   #197 (permalink)
2008 NFR S2000
Cool, I'm curious as I have never dynoed my car, since there is No dyno in my area.
Old 07-30-2008, 04:35 PM   #198 (permalink)
Member # 4524
here is my last dyno.
I am curious as to what the new dyno will bring. Im hoping to be at 210 but i dont think that is possible.
Old 08-05-2008, 02:35 PM   #199 (permalink)
sidecut305's Avatar
FA Crew #81
Hope that helps.
any chance you could add text to your install pics? i think i have the idea down, just want to make sure im not missing anything. please!!!!
Old 08-10-2008, 11:49 AM   #200 (permalink)
Topplayer's Avatar
Jonny Blaze
can this be done with out a air tool or do i have to rent one at auto zone?
Topplayer is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/25328-diy-nst-civic-si-underdrive-pulleys.html
Acura TSX Community - NEW NST pulley kit installation, DIY pics, dyno... This thread Refback 03-02-2008 09:06 PM
DIY ** NST Civic SI underdrive pulleys - Page 7 - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 01:27 AM
TSXClub.com Forums - NEW NST pulley kit installation, DIY pics, dyno... This thread Refback 01-11-2008 05:56 AM
DIY ** NST Civic SI underdrive pulleys - 8th Generation Honda Civic Forum This thread Refback 12-16-2007 02:41 PM
NonStopTuning (NST) K20 SI Kit DIY, Pics, Dynos... - 8th Generation Honda Civic Forum This thread Refback 12-14-2007 04:47 AM
On The Track - 2006 Honda Civic - 8th Generation Civic 2006 Honda webby Honda Industry News 6 08-27-2009 05:35 PM
Welcome to 8thcivic.com - 2006 Honda Civic - 2006 8th Gen Civic webby 8thcivic.com Site News 1 12-31-2006 01:25 AM
2006 NOPI NATIONALS @ Rockingham dragway Qualifiers BATANG CITY JAIL Water Cooler 0 12-12-2006 03:04 AM
2006 Civic Detailed Report webby Garage 2 07-06-2005 11:25 PM
2006 Geneva Civic Release webby Garage 0 06-23-2005 12:10 AM
