Old 01-05-2007, 12:26 PM   #1 (permalink)
hatchbac_smokin_you's Avatar
Problem with the Brakes?
I have noticed a couple of times at the exact same spot, a problem with my brakes.. It is when i get on the brakes pretty hard and am going over a rough road with lots of bumps on the right side. When i hit the brakes i get a weird feeling throught the pedal and the car seems to struggle to stop.. anyone experienced this?
hatchbac_smokin_you is offline   Reply With Quote
Old 01-05-2007, 12:35 PM   #2 (permalink)
bumpidty bump bump
Old 01-05-2007, 12:39 PM   #3 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
Are you sure it's not just your ABS kicking in?
NBPRudy is offline   Reply With Quote
Old 01-05-2007, 12:40 PM   #4 (permalink)
Mattzilla's Avatar
Matt
Sounds like ABS....
Mattzilla is offline   Reply With Quote
Old 01-05-2007, 12:42 PM   #5 (permalink)
can you also set off abs due to road conditions? becuase when i mean i am getting on the brakes its not really that hard.. i am prolly only going like 40 and have to make this right turn...i thought abs was strictly for just antilock.. do they serve other purpose as well? And does the car have a abs light that comes on when it engages?
Old 01-05-2007, 12:46 PM   #6 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
No there won't be a light that comes on.
You say it happens at the same spot,is there loose gravel on the rough road?
If your wheels are not getting traction when braking your ABS will kick in.
Old 01-05-2007, 12:53 PM   #7 (permalink)
no loose gravel just a bumpy part of the road.. i think i am gonna grab a honda tech and bounce to that part and tell him to diagnose...
Old 01-05-2007, 12:56 PM   #8 (permalink)
radiocontrolhead's Avatar
Danny
It's the ABS. Prior to posting this the search feature should have been used. The ABS system in these cars are crap IMO. They go off for any stupid reason and acctually makes things a lot worse. Because of this, I got into a minor accident where I knew the ABS did not need to work, but it did anyway. If I had my way, I'd have them disable that stupid ABS, it makes things worse than better. Lets stick to the old fashion pumping if this was the way the engineered this crap.
My mothers 2004 Accord has 4 wheel ABS and is by far from being as sensitive as the civics. If I wanted to, I can get the ABS to kick in whenever I want in the Civic with very little effort, however, with the Accord, you'd only need the ABS when you really needed it. I've braked really hard in that car a few times w/o the ABS kicking in and thats the way it should be.
Old 01-05-2007, 01:07 PM   #9 (permalink)
thanks for the comments everyone.. and ya i could have used the search but got good feedback here.. its lame that everytime someone puts something in everyone feels so proud when they can name that it has already been posted.. gimme a break.. anyway i will definetly get it looked at and update with the finding..
Old 01-05-2007, 02:07 PM   #10 (permalink)
Danny
No, it's just common sense, you'll find the same amount of "good feedback" in that search button as well. Same exact question had to be asked in about 5 different threads. I'm not trying to bash you or anything but just giving you the awareness that this has been asked.
There really is no need for you to waste your time to get the brakes checked, it's just how sensitive the system is. If brake over anything a bit uneven, my ABS will kick in.
Old 01-05-2007, 02:13 PM   #11 (permalink)
gbae007's Avatar
Keep in mind that tires will affect how often the ABS kicks in. If you have hard compound (touring, etc.) or worn tires, the ABS will kick in more often.
Old 01-05-2007, 02:27 PM   #12 (permalink)
na got the summer tires so the grip is there.. treadwear is only 240
Window Problem waross Mechanical Problems & Technical Chat 14 12-17-2007 05:27 PM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-13-2006 12:24 AM
Brakes upgraded to JDM Euro R Accord brakes pengful Suspension and Brakes 32 08-19-2006 10:21 AM
brakes and gas!! carlossamano2004 Civic SI 14 07-27-2006 12:44 AM
weird anti-lock brakes? carlossamano2004 Suspension and Brakes 17 04-30-2006 11:29 PM
