#6 (permalink) | |
![]() Join Date: Feb 2006
Back and Forth Forever
If there's an issue, they give it a reference number. Learn More: http://www.nhtsa.dot.gov/
#8 (permalink) | |
M.U.R.D.E.R
![]() Join Date: Mar 2006
![]() » Supercharged 2006 Honda Civic Si Coupe » Information/Teaser Video | ROTM | Carbon8mag Feature! » HondaArmy.com |
i don't quite see how up shifting can cause any problems as long as you match the RPMs correctly. If you let them drop down to where they need to be before shifting up, then you should be fine, even if you skip gears. however, if your at 8000rpm in 1st and shift straight to 6th w/out letting the RPMs drop to about 1500rpm, then that would definitely cause wear.
#11 (permalink) | |
