Old 12-28-2006, 03:25 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
datbacker59's Avatar
Its a Live2Hustle Thang...
R18 Oil Change
i went to pepboys and asked the guy what kind of oil my r18 takes and he told me 10w-30. so i bought mobil 1 oil at 10w-30 and changed my oil. then i looked in the manual and it said 10w-20. should i change my oil again or is this fine? my car pulls alot harder and feels alot healther now with mobil 1
datbacker59 is offline   Reply With Quote
Old 12-28-2006, 04:45 PM   #2 (permalink)
Civic Pride's Avatar
I hear it really makes no different, and don't worrie about it, you will not hurt your engine by using 30 instead of 20.
Civic Pride is offline   Reply With Quote
Old 01-02-2007, 05:08 AM   #3 (permalink)
Kidekat's Avatar
I would imagine for fuel mileage sake, and the tighter piston-wall clearance that Honda wants us to run 5W-20 as specify on your oil cap. If you redline it all the time, then going 10W-30 "should" be okay. Just don't expect to achieve the same fuel efficiency as you would with 5W weight.
Kidekat is offline   Reply With Quote
Old 01-02-2007, 05:10 AM   #4 (permalink)
sbigshot's Avatar
You'll be ok with either one!! +1 rep for changing your own oil.
sbigshot is offline   Reply With Quote
Old 01-02-2007, 06:31 AM   #5 (permalink)
Andrei'sCivic's Avatar
Andrei
You listened to someone that worked at Pepboys? And they were wrong. Honestly, it says what weight to use on your oil cap and in your owners manual. Even if you used 10W-30 synthetic I still think your engine will have an "easier" time reving with 5W-20 synthetic or not. Its all mental. you want to believe that it runs better. Probably a little smoother cause its a thicker oil which provides a thicker film of oil between metal parts.
Andrei'sCivic is offline   Reply With Quote
Old 01-02-2007, 12:51 PM   #6 (permalink)
m1k3's Avatar
5w30 ftw
m1k3 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/24495-r18-oil-change.html
R18 break in oil consumption - 8th Generation Honda Civic Forum This thread Refback 12-09-2007 12:03 PM
Oil Change DIY ethlar Engine 334 06-29-2009 02:24 AM
Everything Oil: All you'll ever wanna know atruhondagrl Bolt-Ons And All-Motor 14 06-16-2008 12:45 PM
Oil Change Info. jc21 Garage 7 07-16-2007 07:59 PM
Recent oil change with lab results ChristopherSi Garage 12 11-03-2006 12:43 AM
First oil change. Why wait?, Because... blanz Bolt-Ons And All-Motor 8 10-31-2006 02:19 PM
