Old 12-24-2006, 07:27 PM   #1 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
Changing MTF to Amsoil.
I am going to change my MTF fluid to Amsoil's MTF fluid. I hate this 3rd gear problem. I also heard that the first 500 miles of a new car's tranny is crucial to using proper fluid. Since Honda used the wrong fluid in the first place, I hope I didn't damage my FG2's tranny.
I will post results ASAP.
Old 12-24-2006, 09:19 PM   #2 (permalink)
I'm planning on doing the same. I don't have any of the tranny problems with my Si that some people are having, but I found with both of my previous Civics, switching to a higher quality synth/semi-synth greatly improved the shifting especially in the cold.
I don't think Honda used the "wrong" fluid. They use the same fluid for every single car no matter what model of car, the tranmission is in it or it's intended purpose.
DumbasSi is offline   Reply With Quote
Old 12-24-2006, 09:43 PM   #3 (permalink)
where do you plan on getting the fluid? is it sold in local stores?? i'm just wondering, b/c i'm popping down to portland and will look for it there, if its not locally available
also, we'd need new washer's for the drain plug, which are the specific ones we use?? (i just like to have all my facts in place before starting a mino-project)
ianwells100 is offline   Reply With Quote
Old 12-24-2006, 09:57 PM   #4 (permalink)
http://www.amsoil.com/StoreFront/mtf.aspx
I'm sure there is a dealer locator on the site somewhere.
A local Honda dealer should be able to supply you with the correct washer. I plan on using a magnetic plug just to pick-up any metal shavings that might be floating around.
http://www.passwordjdm.com/product.a...on=1&P_ID=1109
Old 12-25-2006, 02:12 AM   #5 (permalink)
thanks, didn't realize it was so easy to order online from Amsoil... $22.xx CDN all in is pretty good for 2 quarts...
i'll get some washers when i get my free oil change at the dealership, then i'm all good to go!
Old 12-25-2006, 02:18 AM   #6 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
My mom's co-workers husband is an Amsoil dealer/rep so I get it @ cost.
:) PM if you want some
Old 12-25-2006, 05:54 AM   #7 (permalink)
PM'd
Old 12-25-2006, 12:11 PM   #8 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
PM'd back!
Old 08-08-2007, 10:24 PM   #9 (permalink)
07 Figi Blue Si's Avatar
Lance
Hey-
I have a post on similar, but changing to GM Syncromesh. I have an issue with weather or not to add the "Limited Slip Axle Lubricant Additive", which is recommended by GM for LSD applications. The product known as "GM Syncromesh with Friction Modifier" is not the same at all. The former is for LSD and the latter is for reducing gear wear, but won't do a thing for LSD. Input on this additive? Is it already contained in the Amsoil product or not? OK for LSD's per Amsoil? What do you think-add it or not??? Comment???
07 Figi Blue Si is offline   Reply With Quote
Old 08-09-2007, 12:13 AM   #10 (permalink)
My amsoil is on the way.....i guess i need to get one of those pumps to fill it from underneath?
legendman is offline   Reply With Quote
Old 08-09-2007, 12:30 AM   #11 (permalink)
Originally Posted by 07 Figi Blue Si
Hey-
Our LSD is only helical type, which is gear type not clutch packs. Don't think there's need for the additive since there are no clutch packs.
Voodoo is offline   Reply With Quote
Old 08-11-2007, 04:54 AM   #12 (permalink)
Daren07si's Avatar
Daren
G.M. tech reply on product?
the GM product only works on GM gear oil fliuds not on front wheel drive. cause it is only for the rear drive, you have to check if there is an additive for the transfer case. 4x4 additive is actually good for any 1 or 2 leger car.
it made my dc4 01 better before. this was the fluids good for honda and acura tranny from 1989-now royal purple 20-50 syn & 20-40 reg oil castrol with Lucas transfer case additive. and winter royal purple 10-40 syn & 10-30 reg oil castrol Lucas tran. additive.
Engine are almost same royal purple 20-40 syn. and 10-30 reg. oil castrol on summer. Cold run 10-40 syn & 5-40 reg oil. it will save your compression and secondary rings.
have fun boys. G.M. and Honda tech.
Daren07si is offline   Reply With Quote
Old 08-11-2007, 10:52 AM   #13 (permalink)
dentrecords's Avatar
if you have a CAI, I've also heard of people filling it from above with a funnel and tube.. man I wish I'd thought of that before filling from underneath..
Originally Posted by 2fast4u2
yee hawww
DIY: Changing Manual Transmission Fluid BATANG CITY JAIL Transmission 398 11-19-2008 09:38 PM
Amsoil 5w-30 in R18 EX Sedan iVTEC Mechanical Problems & Technical Chat 7 03-29-2007 01:23 AM
Made a big mess changing out the oil BoneStock Do It Yourself Articles 15 01-04-2007 02:48 PM
Changing my r18 grill to an si will i loose warrnty lightlypurified Garage 4 09-10-2006 06:13 PM
About Oil Changing.,.... kenken3686 Mechanical Problems & Technical Chat 39 08-29-2006 03:18 PM
