Old 12-21-2006, 12:10 PM   #1 (permalink)
Rattles!!! in cold weather????
do you guys experience some rattles in cold weather?? i have some small rattles in my 06 EX Coupe.. but this month when the weather gets cold I notice some rattles on the passenger side door.. i dont have this rattle before.. thanks!!!
baddazzcivic is offline   Reply With Quote
Old 12-21-2006, 12:34 PM   #2 (permalink)
i sure do, i hear rattles everywhere, i took my 06 civic ex to honda and they found a rattle around the subwoofer, they took it apart and put insulation in. that rattle is gone but now there are rattles in the passenger door and creaking sounds... can't wait til winter is over!
Jdm-Ty is offline   Reply With Quote
Old 12-21-2006, 12:44 PM   #3 (permalink)
Avenger's Avatar
Rob
Yes sir........had no rattles until the colder weather hit.........then later in the day when it was a bit warmer, the rattles went away.
Avenger is offline   Reply With Quote
Old 12-21-2006, 12:48 PM   #4 (permalink)
CNUco2007's Avatar
Eric
yea i had no rattles until the cold weather hit lol But now I sure do. all well... once it warms up again in the spring, i'm sure they'll go away... Darn cold making things contract and stuff :P
CNUco2007 is offline   Reply With Quote
Old 12-21-2006, 12:59 PM   #5 (permalink)
Yes indeed but as the car warms up it all gets better.
FTalento is offline   Reply With Quote
Old 12-21-2006, 01:55 PM   #6 (permalink)
YES, my 06 LX sedan has plenty of rattles. My car was rattley when I bought it but the colder weather makes them worse.
Old 12-21-2006, 02:05 PM   #7 (permalink)
+1
vetkiller is offline   Reply With Quote
Old 12-21-2006, 05:25 PM   #8 (permalink)
dentrecords's Avatar
I should figure out what temperature my car doesn't rattle at and just keep my garage at that temperature all the time..
Originally Posted by 2fast4u2
yee hawww
Old 12-21-2006, 06:04 PM   #9 (permalink)
JeShUa's Avatar
swagger so tight
haha.. when I gave someone a ride,,, they were like,, man your car is hecka quiet,, I'm like,, YOU DONT HEAR THAT? lol... OCD much?
Old 12-21-2006, 06:31 PM   #10 (permalink)
tennisfan16's Avatar
I know what you mean, i only have a couple small rattles, and when people are in my car they never notice them but they bug the crap outta me.
tennisfan16 is offline   Reply With Quote
Old 12-21-2006, 07:01 PM   #11 (permalink)
07SiGuy's Avatar
Yup, mine rattles like a baby toy when it's below 30 degrees. But like others have said.....it goes away by afternoon and a little sunshine.
07SiGuy is offline   Reply With Quote
Old 12-21-2006, 07:02 PM   #12 (permalink)
BLU BY U's Avatar
its just the plastic getting stiff....i dont really notice it since i listen to the radio so much.
Old 12-21-2006, 07:31 PM   #13 (permalink)
I agree.. that’s the only fix to avoid hearing those rattles on cold weather.. turning up the volume up .. 12+ .. i went to honda dealer last week coz they have the 07 tw si.. the sales manager ask me if i could stop by at noon.. told him ill do it first thing in the morning (when the weather is cold) .. and sure enough i noticed the same rattles as my 06 ex coupe..
Old 12-21-2006, 10:04 PM   #14 (permalink)
Si 07's Avatar
noise rattle
hi, I just got my new civic last sunday, so far from everyone says here the rattle sounds are normal in cold weather, mine is by the glove compartment i think, my friend says it sounds like little bits of sand being tossed at the body paint. just wondering if thats normal for all the new civics. its currently winter here, 30 degrees i hope thats it.
thanks for any info regarding this
JP
Si 07 is offline   Reply With Quote
Old 12-21-2006, 10:24 PM   #15 (permalink)
stevieray's Avatar
DP Squad Member #2
Cold cars rattle. Period. Plastics & metals contract and fitment is just a smidge off. Just the nature of the beast.
Hell, I rattle when I get cold. 51 years of doing things I shouldn't will do that for ya.
stevieray is offline   Reply With Quote
Old 12-21-2006, 11:10 PM   #16 (permalink)
Si 07's Avatar
oh never knew, i had a Integra GS stick, since i was 16, super nice car learned a lot of things driving it, it never had any noise when it was winter like the rattling. but i guess new car new things to learn heh, thanks for the info
Old 12-22-2006, 12:18 PM   #17 (permalink)
JP
i had the same rattle with the glove box ... mine is not aligned correctly ... the right side of the glove box is grinding againts the dash ... what I did is simply lossen up the 2 screws and put some paper on the part thats grinding ... close the glove box and tighten the two screws ... after that I remove the paper and viola no more rattle ... just an fyi ... hope this helps ...
Old 12-22-2006, 12:34 PM   #18 (permalink)
civic si hb's Avatar
i get some pretty serious sqeeks and rattles any in the 30 degree range, anything from 40 degrees and up i'm rattle free
civic si hb is offline   Reply With Quote
Old 12-24-2006, 01:17 PM   #19 (permalink)
I found out what rattles in my 07 ex. When I position the fan dial all the way to OFF position, it still rattles while it is in panel or panel and feet mode. However, if I put the fan in feet only mode, the rattle is gone, at least the major one. So I guess, fans still work even though you turn them off.
My TL had similar problem, the rattle was louder, but that was a 10 year old car!
xxhaimbondxx is offline   Reply With Quote
Old 12-30-2006, 12:41 PM   #20 (permalink)
thekurgan's Avatar
Victor Kurgan
I found several rattles from wires, cables and even the rear trunk drain tube. I removed the side trunk panels and used wire ties to lock everything to the metal frame that was loose. If you tie up the drain tube, make sure it's still locked into the end tube so the water doesn't fill up your trunk! I also used several pieces of adhesive felt where wires were forced to come into contact with metal, like around the upper section of the trunk near the subwoofer. For the plastic squeaks and rattles, I used graphite (powder) where the plastic meets plastic. The stuff is odorless and lasts a very long time.
thekurgan is offline   Reply With Quote
Warm Vs Cold Weather heron126 Civic SI 6 12-10-2006 10:34 AM
cold weather affect? Exeon Inside and Out 1 10-16-2006 03:17 AM
SRI cold air. Marin Forced Induction And Nitrous 18 06-24-2006 11:08 PM
Window tints + rattles + honda warranty = ? dlux200sx Inside and Out 0 05-02-2006 10:16 PM
