WHAT'S THE PROBLEM???????? - 8th Generation Honda Civic Forum
Old 12-19-2006, 04:22 AM   #1 (permalink)
strCIVIC's Avatar
my car is dropped with tein s-tech with 17" rims...the problem is that when i turn the steering wheel it makes that weird noise...its like i dunno how to explain it..and no its not rubbing but seems like its the axle or something but don't know...any of you mechanic out there know??stressing me out alot..whenever i turn the steering wheel it makes noise.. checked the steering fluid and its full..checked under the car but there's nothing i can see that's causing the problem..and the alignment still good also..??????????????????
strCIVIC is offline
Old 12-19-2006, 04:27 AM   #2 (permalink)
fa1
fa1's Avatar
Like a creaking noise? I have it also. i think it's the upper strut mount or where the front spring sits on the strut.
Old 12-19-2006, 04:42 AM   #3 (permalink)
BATANG CITY JAIL's Avatar
grease...grease....more grease..... or you over tighten it...
Old 12-19-2006, 04:57 AM   #4 (permalink)
strCIVIC's Avatar
yeah a creaking noise....but how do we fix this???put grease where though???maybe yeah..over tightened something...cuz they used power tools when they installed my springs...but yeah i'll check the car tomm again...cuz when my car was on the car hoist and actually turn the steering wheel it didn't make that noise.. but i still want to know the exact place where the noise at..
strCIVIC is offline   Reply With Quote
Old 12-19-2006, 05:01 AM   #5 (permalink)
if it's the creaking noise, yeah I got it too. At first I thought it was the engine mount so I took it to honda and after doing their thing determined that it was the suspension. Needless to say, they won't even touch my suspension since it's been modded by someone else. However, they did say that if I turned it back to stock then they can look at it. As for now, as long as nothing's broken I'm gonna leave it and just deal with the noise.
56civic is offline   Reply With Quote
Old 12-19-2006, 05:21 AM   #6 (permalink)
you know what you do...just loosen some screw up then try to rotate the spring slowly where they be sitted nicely... then tighten it on on the right spec... apply a grease on the top mount, just a little or ealse it will collect a sand/little stone....
i bet its the spring, it didn't sit right...
Old 12-19-2006, 05:29 AM   #7 (permalink)
strCIVIC's Avatar
i think it's the spring too...cuz i was cleaing the wheel well for the HIN and i did turn the pass. side front spring to the left a little ...
Old 12-19-2006, 09:05 AM   #8 (permalink)
Biggeo's Avatar
Mine does it too. Drives me ape sh!t. It's the spring and an incorrect install. Not seating correctly. Had it...at least they tried...to fix it once already...no go. Even put the stockers back on. That fixed it, but once the Tein springs went on, back to the creaking...sucks man.
Biggeo is offline   Reply With Quote
Old 12-19-2006, 10:52 AM   #9 (permalink)
reelbigfish241's Avatar
Jason dSLR Squad #27
I'm thinking about getting some teins. Is this problem because of the springs, or the install?
reelbigfish241 is offline   Reply With Quote
Old 12-19-2006, 04:06 PM   #10 (permalink)
fa1
fa1's Avatar
I would believe it to be the springs. I'm sure most aftermarket springs does it.
Old 12-19-2006, 04:11 PM   #11 (permalink)
my drivers side does this too....very annoying but it's been like that for sum months now.....i know if i put grease in it, it will go away b/c when it gets wet it stops making the noise, but i'm too lazy....
Old 12-19-2006, 05:49 PM   #12 (permalink)
so it's definitely the springs then?? the guys that installed my Teins are the best over here and they've installed many springs, so I'm pretty sure it has nothing to do with the install.
which makes me ask, what's up with these Tein S-Tech's? everybody experiencing noises with theirs?? if it's just noise then that's fine, but I'm worried if it's anything else (read quality or manu. defects).
Old 12-19-2006, 08:27 PM   #13 (permalink)
strCIVIC's Avatar
if its really the spring...what's up with TEIN????i thought they tested the s-tech before producing thousands???DAMN TEINS!!!lol..really bothers me alot..
Old 12-19-2006, 09:19 PM   #14 (permalink)
^^ as i said try to turn the spring around... or apply a little bit of grease..
Old 12-20-2006, 11:10 PM   #15 (permalink)
Rocco's Avatar
I had a noise like this on my EP3..i had aftermarket suspension put in right when i got it..during all 3 years of owning, it always made this clunking noise....i had it checked numerous times...nothing ever bad happened...guess it just comes with being lowered
Rocco is offline   Reply With Quote
Old 12-21-2006, 12:33 AM   #16 (permalink)
i remember a thread about springs a while back. i hear tiens springs makes that noise in the car so it's normal. our cars are pretty new so parts are not really perfected yet. i hear megan springs are have no problems now... but the drop isnt that low at all. there were some problems with it b4 but it's all fix. i hope teins will have their product fixed soon. btw.... how do u guys like your springs? besides the noise that is
freekaingjon is offline   Reply With Quote
Old 01-10-2007, 10:49 PM   #17 (permalink)
strCIVIC's Avatar
i finally had the time to turn the spring around...and it did work man.. ..cuz like i said..i did turn the spring when it was getting ready for the HIN..
Old 01-10-2007, 10:52 PM   #18 (permalink)
good to hear that you finally fixed it..
a rep would be appriciated..
MODs quick
Old 01-10-2007, 11:08 PM   #19 (permalink)
did u mean u flipped the spring....or just turned it???....i have this problem and it's been like this for a while i've learned to live with it but it would be nice if it was gone....advice thanx
Old 01-10-2007, 11:45 PM   #20 (permalink)
you just gonna have to turn it not flip it... find the spot when the spring sits real good...
you seen my first car? 05 ex, i have a full coilover on those and they squeek like every bump...but i fixed it by turning them...
Window Problem waross Mechanical Problems & Technical Chat 14 12-17-2007 04:27 PM
rear shock problem ziggy Mechanical Problems & Technical Chat 30 04-07-2007 07:48 PM
RE: Galaxycivic Amp problem damon300s I.C.E., Electrical, Security, & Navigation 2 12-26-2006 10:48 PM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-12-2006 11:24 PM
