Old 12-18-2006, 08:16 PM   #1 (permalink)
Amir
Electrical problem
Okay guys, another problem. My car is turned on, and all of the windows are up, and my head lights are turned on. If I pull the driver window switch up (yes, I know the window is closed) my headlights become less bright. Is this a problem in electrical system? Is it common? any solution?
Thanks
Amir
amirh is offline   Reply With Quote
Old 12-18-2006, 08:21 PM   #2 (permalink)
airportguy770's Avatar
Dave
Mine used to do it to, but not I'm running PnP HID and they have a ballast which I think fixed that problem. I used to have a silverado and it did it too when I pulled up on the window switch. I think its normal, because the window is already up and the motor is still trying to move it.
airportguy770 is offline   Reply With Quote
Old 12-18-2006, 10:52 PM   #3 (permalink)
yeah it's normal, all the cars i've owned have done this
inline4 is offline   Reply With Quote
Old 12-18-2006, 10:55 PM   #4 (permalink)
Ryd1ZZ's Avatar
Ryan
normal, but I think a grounding kit will fix or help this...but not positive
*edit* nevermind my comment, I suck
Ryd1ZZ is offline   Reply With Quote
Old 12-18-2006, 11:03 PM   #5 (permalink)
Amir
Thanks guys, I appreciate it :)
Old 12-18-2006, 11:04 PM   #6 (permalink)
its normal
youre basically asking the motor to try and overcome the door causing it to use more current so it creates a bigger drain on the system. since the door is exerting the same amount of force back to the motor there is no way that it will overcome it.
a grounding kit will not "fix" it
dannn is offline   Reply With Quote
Old 12-18-2006, 11:09 PM   #7 (permalink)
Ryd1ZZ's Avatar
Ryan
Originally Posted by dannn
its normal
Thanks, I'm new to the car scene :)...what is the grounding kit for, help me out
Old 12-18-2006, 11:48 PM   #8 (permalink)
Amir
The windows system could be designed in such a way that if the window is closed and the window switch is pulled up, the window motor stays off. Does not seem that complicated !
Window Problem waross Mechanical Problems & Technical Chat 14 12-17-2007 05:27 PM
rear shock problem ziggy Mechanical Problems & Technical Chat 30 04-07-2007 08:48 PM
RE: Galaxycivic Amp problem damon300s I.C.E., Electrical, Security, & Navigation 2 12-26-2006 11:48 PM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-13-2006 12:24 AM
upgrading your electrical system CivNick I.C.E., Electrical, Security, & Navigation 9 08-28-2006 09:08 PM
