Old 12-18-2006, 11:09 AM   #1 (permalink)
Amir
is the transmission damaged?
Hello everybody,
I did something really stupid. Yesterday, I was driving my Civic and I dropped my wife at a grocery shop, and I was waiting for her in front of the shop, after a while I turned off the car without putting the shifter in P(so the shifter was in D). When my wife came back, I turned on the car, and because the shifter was still in D, car suddenly jumped! I felt really bad ! Do you think anything bad happened to the transmission?
I am so stupid !!!
Thanks
Amir
amirh is offline   Reply With Quote
Old 12-18-2006, 11:12 AM   #2 (permalink)
Black Si's Avatar
Im sure it wasnt good but it will be ok..
Black Si is offline   Reply With Quote
Old 12-18-2006, 11:13 AM   #3 (permalink)
Si 4 Life's Avatar
James
Your transmission will be fine.
Si 4 Life is offline   Reply With Quote
Old 12-18-2006, 11:25 AM   #4 (permalink)
n00b retro whore
ethlar's Avatar
you actually got the car to crank in D, i didnt know that was possible. Im sure the car is fine though
Old 12-18-2006, 11:35 AM   #5 (permalink)
Kakashi's Avatar
+1, the car shouldnt be able to turn over in D. Its like a safety.
Old 12-18-2006, 12:05 PM   #6 (permalink)
Amir
Thanks guys, I feel relieved .
Old 12-18-2006, 12:08 PM   #7 (permalink)
fuller083's Avatar
Might wanna go get it looked at and figure out why you could start it in D. Most auto cars won't even let you turn it on...
fuller083 is offline   Reply With Quote
Old 12-18-2006, 12:11 PM   #8 (permalink)
Amir
But before that, I should make sure that this is not a common behavior among all civics. because if this is common, there is nothing the dealer can do about it. Is everybody sure that Civics will not start when the shifter is in D?
Old 12-18-2006, 01:41 PM   #9 (permalink)
I'm pretty sure the civic can't start in D, it shouldn't even crank. Same went for my old accord.
Old 12-18-2006, 01:47 PM   #10 (permalink)
Amir
mmmmmm...
I do not know why mine started. It is really strange. I know that you can not pull the key out if the shifter is in D. Maybe the reason is that I did not turn the key to the OFF position, I turned it to the accessories mode(I wanted to listen to radio). Maybe if you turn the key to the OFF while the shifter is in D then you will not be able to turn it back to ignition position. I will try this later today.
Old 12-18-2006, 01:57 PM   #11 (permalink)
radiocontrolhead's Avatar
Danny
There should be an electrical lock out in any case when your transmission is in it's drive gears. Strange.
Old 12-18-2006, 02:07 PM   #12 (permalink)
yea its called the neutral saftey switch. wont let your car crank unless the lever is in park or neutral
id get it figured out if something is wrong or if its normal for AT civics
dannn is offline   Reply With Quote
Old 12-18-2006, 02:16 PM   #13 (permalink)
Kakashi's Avatar
i will go try right now.
be right back.
Old 12-18-2006, 02:24 PM   #14 (permalink)
Kakashi's Avatar
yeah, mine doesnt even crank.
get that checked..
Old 12-18-2006, 02:45 PM   #15 (permalink)
WooooHooooo
darna's Avatar
Ate Vi
it happened to me last night and like most people say, the car won't start.
i don't know why yours jumped on you when u started it...
i'm confused.
The last time I was inside a woman was when I went to the Statue of Liberty
darna is offline   Reply With Quote
Old 12-18-2006, 03:06 PM   #16 (permalink)
Amir
OK, it seems that something is wrong, I will get it checked later today.
I will update you.
Thanks
Amir
Old 12-18-2006, 03:13 PM   #17 (permalink)
razer's Avatar
ive done that too but i put it in park before i turned it back on...
oh well, the car is sold now anyway..ha
razer is offline   Reply With Quote
Old 12-18-2006, 03:56 PM   #18 (permalink)
try starting it in each posistion and post results here. it could be the switch is misadjusted or shorted.
just take it back to the dealer since you have warranty.
Old 12-18-2006, 08:10 PM   #19 (permalink)
Amir
I will try it tonight and post the results.
Old 12-18-2006, 08:23 PM   #20 (permalink)
kjg48359's Avatar
Hey, it sounds more like you might not have turned the vehicle off. Actually, trying to move a vehicle with an electrical starter motor is not something that the starter was designed for. I would have a shop double check that (make sure that something wasn't forced out of place, or a damaged cog/tooth/engaging mechanism).
kjg48359 is offline   Reply With Quote
All this power: what about the transmission? Omes Forced Induction And Nitrous 3 11-29-2006 01:59 PM
Honda Begins Production at Georgia Transmission Plant webby Honda Industry News 2 05-19-2006 03:37 PM
Transmission Question RockALittle250 Garage 4 04-28-2006 04:55 PM
Found out today my transmission is probably going to be replaced. enter801 Mechanical Problems & Technical Chat 25 04-04-2006 09:49 AM
