Originally Posted by cas909
I just replaced my stock cover with the jdm one but i tightened the front right valve cover bolt too tight and the bolt snapped. (i applied 7.5 lbs of torque). I was able to barely put it on but without the metal cover thing that goes over the bushing. im afraid that it wont seal right since that one bolt broke off. anyone got suggestions. also how would i even replace it.
Go back to honda and order a new bolt. I did the same thing with the bottom left front bolt. I can't seem the remember the part number they will be able to help you out at honda or acura. The same part is used in the RSX so if honda dont have it go to acura.
I believe it cost something like 6$ ~ 10$.
Remember that the valve cover bolts there are two different types so make sure you get the right ones.
GL
