Old 12-16-2006, 01:39 PM   #1 (permalink)
hondasi006's Avatar
coolant overflow tank flopping around
i was looking under the hood and i noticed that the coolant tank was just sitting there not mounted to anything, if any one gets a chance could you let me know if yours is like that or if its mounted and sturdy
hondasi006 is offline
Old 12-16-2006, 01:40 PM   #2 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
it slides onto the back of the battery tray. It is not bolted to anything but this does keep it from moving around. Just pick it up and turn it around and you will see there is a cutout on the back where it slides on the the bracket right behind it. I'll try and post a picture when I get home.
Originally Posted by Gonzo View Post
if I found out I was pregnant at 16 I think I'd be flipping the *#&% out.
jed = hermaphrodite
twistedframe is offline
Old 12-16-2006, 01:45 PM   #3 (permalink)
hondasi006's Avatar
thanks, it is not goin to go anywhere its tucked in there pretty tight,
Old 12-16-2006, 03:20 PM   #4 (permalink)
cappykd's Avatar
Kirk
To put it back the easy way, you need to remove the battery and you will then see the part twistedframe is talking about. I just had my tank out yesterday. It clips into the front side of the battery tray. Basically you just slide it into the bracket.
cappykd is offline
What coolant should i use... lou10788 Mechanical Problems & Technical Chat 7 11-07-2006 03:37 PM
My Si is using coolant michaelbgone Mechanical Problems & Technical Chat 0 10-03-2006 08:56 PM
How to install heat shield intake gasket and bypass TB coolant on 06 si. 06redsi Civic SI 30 08-16-2006 10:20 PM
Coolant Leak Jasonbergmann Mechanical Problems & Technical Chat 5 07-07-2006 10:52 AM
