Old 12-15-2006, 08:09 PM   #1 (permalink)
Power Steering Fluid
Can we use any kind? Sorry i am a newb to this. What kind of power steering fluid does our cars use?
victor is offline   Reply With Quote
Old 12-15-2006, 10:09 PM   #2 (permalink)
TT
uhhh.... i don't think we use any...
its electronic power steering thingy... yea... no power steering in our car, cause theres no fluid.
thaijai114 is offline   Reply With Quote
Old 12-15-2006, 11:32 PM   #3 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
If you have a non-si I would just recommend oem power steering fluid instead of mixing some aftermarket brand in.
Old 12-15-2006, 11:51 PM   #4 (permalink)
ALL 06 Civics use Electric Steering.....meaning no PS needed......
.....IF u own a HONDA that uses PS.....u should ONLY use HONDA specified PS......other PS fluids wear out the bushings inside the steering rack.
Old 12-16-2006, 12:19 AM   #5 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
I'm positive that only the Si has electric power steering.
Old 12-16-2006, 01:05 AM   #6 (permalink)
that's right i do remember changing the subframe on a non-si civic and it did have PS.....i was just too lazy to fix my post
Old 12-16-2006, 06:53 PM   #7 (permalink)
Steve
I can't confirm whether or not the Si has electric power steering but I "can" confirm that my '06 EX sedan does not. I just went and looked, and found the reservoir with the little red cap that says, "Use ONLY genuine HONDA power steering fluid."
Drive Safe, :)
Steve R.
Intrepid175 is offline   Reply With Quote
Old 12-16-2006, 07:32 PM   #8 (permalink)
well i'm positive that the Si does have electric steering
Old 12-17-2006, 02:16 AM   #9 (permalink)
TT
hmmm, i didn't no non-si had no electric steering. sorry about that
Old 12-17-2006, 03:38 AM   #10 (permalink)
Ok i went to checkers and bought a Power Steering Fluid. The regular ones were like 2 bucks but i decided to buy the one that said "For honda Cars" it was like 5 bucks.
Old 12-17-2006, 04:14 AM   #11 (permalink)
NOOOOOO......don't do it........go to the dealer and get HONDA GENUINE PS FLUID
Old 12-17-2006, 04:28 AM   #12 (permalink)
YOGIx213's Avatar
Well, on the Honda website, when you compare the Si to the EX model, it shows both have "rack and pinion" steering.
Don't know though if it uses power steering fluid.
http://automobiles.honda.com/tools/c...Photo=&Change=
http://www.edmunds.com/ownership/tec...1/article.html
YOGIx213 is offline   Reply With Quote
Old 12-17-2006, 04:29 AM   #13 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
It also shows the Si has electric while the other trims have standard.
Old 12-17-2006, 04:33 AM   #14 (permalink)
rack and pinion is just another name for steering rack........pretty much every car made has a rack and pinion
Old 12-17-2006, 04:43 AM   #15 (permalink)
YOGIx213's Avatar
So the Power-assisted rack-and-pinion steering that is says on both the Si and the other models are different? I didn't know that. The site gets a bit confusing when you click on comparing models. For example, in the comparison section, it shows that the Si has a Mcpherson Strut front suspension but the Ex has "Independent." When you look at the EX specs on it's own though, it reads that it has a Mcpherson Strut Front Suspension as well.
Old 12-18-2006, 03:05 PM   #16 (permalink)
F*ck is it bad? should i get it flushed?
Old 12-18-2006, 03:18 PM   #17 (permalink)
i was always told by many many diff. technicians that honda steering racks need Honda Genuine PS Fluid b/c of the bushings inside....i guess that other PS fluids r too aggressive or something and will mess up those bushings.....if it said it was for Honda cars then i guess it might be ok.....but i would just stick with the Genuine Honda stuff.
Old 12-18-2006, 05:24 PM   #18 (permalink)
yah, the regular power steering fluid was hella cheap and when i saw the honda power steering its like 3x more the price. so hopefully i get what i paid for. thanks for the advice.
Power Steering Noise Civic_DC2 Mechanical Problems & Technical Chat 3 03-21-2007 05:18 AM
Power Steering Leak problem----Anyone else??? atomicEXcoupe Mechanical Problems & Technical Chat 1 10-16-2006 10:59 PM
Power Steering Decided it wanted to peace out!! FckThatSht Mechanical Problems & Technical Chat 9 08-28-2006 10:12 PM
Power Steering Problem daveswift Mechanical Problems & Technical Chat 0 07-19-2006 02:35 AM
power steering ??? tc5953 Civic Coupe And Sedan 7 05-02-2006 08:27 PM
