Old 12-09-2006, 10:40 AM   #1 (permalink)
Rumble sound?
Lately I been getting what seems to be a "mmmmm" vibration noise when I step on the gas slightly... coming from the front. It varies though, if I step on the gas more... it goes away or seems so. If I step too little, it may not or it may but if I step it to a certain amount and just right... it is very noticable...
A rattle, or vibration like problem from the front... I can't think of what besides the possibility of the radiator resevoir or bumper?!?!
Any ideas. they seem to check ok, help! oh and I notice it more when going up a hill!
06xy is offline   Reply With Quote
Old 12-09-2006, 12:58 PM   #2 (permalink)
06 Civic EX Sedan-Engine Noise at 1400 RPMs
Old 12-09-2006, 02:50 PM   #3 (permalink)
If it happens between 1300-1700 rpms and is really pronounced at 1400-1500rpms then use that link that av911 provided, look for the TSB # for the fix for the buzzing sound. Take it to the dealer and get it fixed, good luck!
Old 12-13-2006, 03:10 PM   #4 (permalink)
I printed out the Honda TSB, and will go to where I bought the car this weekend to get it checked out. Thanks!
I may even call later today to have it talked and schedualed so incase they have to order the part. They can do so now!
Old 12-13-2006, 03:16 PM   #5 (permalink)
nice, keep us posted. I got the tsb done nearly a month ago, and the noise is gone. You might still slightly notice the sound, but it's nearly impossible to tell, no more rumble at all.
Old 12-14-2006, 01:15 PM   #6 (permalink)
Was it random? because sometimes its noticable while other times I have to try and make it noticable or maybe it just won't happen.
I notice it more when going up a hill or elevation rather then flat and I am taking it in tomorrow morning.
Old 12-14-2006, 08:15 PM   #7 (permalink)
For me, it wasn't random...1400-1600 rpm. When going uphill, it tends to hold at that rpm.
Old 12-14-2006, 09:25 PM   #8 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Is it a whistling sound?
Old 12-14-2006, 10:06 PM   #9 (permalink)
Its not a whistling sound, its more like a rumble or vibration.... like bbmmm or mmmmmm. If I let go of the pedal it stops, if I put a bit, it may happen aid if I put a lot it doesn't
I checked my vin, I am not sure if its in the list but it is a 1h just the alldata isn't very detailed for me to be sure I am in there according to vin.
I am going in at 8 tomorrow to let honda check it out
Old 12-14-2006, 11:27 PM   #10 (permalink)
Try keeping your rpm's at 1400rpm at a slight incline and kep it above 30mph. I think mines was the most obvious @ 1400rpm and 38mph or so up small hills/inclines.
Old 12-15-2006, 10:30 AM   #11 (permalink)
Welp... I am at the Honda dealer right now.... the waiting room to be exact.
Jason, yours sound like mine. Its most obvious on inclines at low rpm... ever since this happened. It feels as if the shift won't drop when needed *staying high rpm* for an auto! I filled up this morning prior coming to the honda dealer. I calculated... only 28mpg compared to my previous 3-5 fill ups of at least 33mpg.
I gave them a print out of the link of the alldata.
I asked how long, they said roughly 1-3 hrs depending what the problem is. I told him. If you have the part, just change the drive belt as mentioned in there. All the symptoms match very closely, if not exactly.
I hope this fixes and gets my mpg back as well as the annoyin noise, shift and its a new car! I just hit roughly 4,1xxk only today!
Now I am waiting, kind of bored... wish they let me test drive an s2k... hahaha I will hit the show room next. Wish I brought my nice camera now....
Ok I am babeling so I guess I will type something more useful. Uhm... The holiday is near, everyone keep your car clean and out of sight if you plan to pack. Use your trunk! is big, roomy and useful!
Old 12-15-2006, 12:36 PM   #12 (permalink)
Well it is done, don't feel much difference yet... will test it more later on to see if it is fixed.
Part replaced was 04301-rna-307 kit .belt 56992
Thought I share that incase
Old 12-15-2006, 02:10 PM   #13 (permalink)
gbae007's Avatar
Are you auto and manual transmission? Did the fix make a difference for you?
Old 12-15-2006, 06:16 PM   #14 (permalink)
What do you mean Auto and manual?
Mine is pureley auto not manual and civics don't have sport shifts... "auto and manual"? That is the first I heard~ hahaha
The symptoms seem to be gone but I can't be for sure yet until I test it more but so far, I do not hear the vibrations anymore and the shift seems to be responsive when it needs to downshift. As oppose to when this started to happen. It would stay at, say 3k and unless if I push it more, will it drop.
Old 12-18-2006, 12:36 PM   #15 (permalink)
gbae007's Avatar
Sorry I meant auto OR manual.
Thanks for the helpful info.
Old 12-19-2006, 12:13 AM   #16 (permalink)
PokeyD16Z's Avatar
I have a manual. Took the car in this morning for an oil change and mentioned the rumbling/buzzing at 1500...they've ordered a new belt and will install it when I return from vacation on 1/5/07. No questions asked.
Proper Sound Dampening ballplaya4237 I.C.E., Electrical, Security, & Navigation 23 09-29-2008 07:03 AM
popping sound from right front(passenger side) sickyute Suspension and Brakes 14 11-24-2007 07:19 AM
New Civic Coupe LX - 140 CRAP SOUND SYSTEM :( Need help to change hondapower Civic Coupe And Sedan 30 10-16-2007 06:21 PM
Strange humming sound? chylld Mechanical Problems & Technical Chat 21 10-02-2006 03:03 AM
Sound Quality in the 06 civic hamm I.C.E., Electrical, Security, & Navigation 9 12-30-2005 09:41 AM
