Old 11-28-2006, 01:43 AM   #1 (permalink)
MrPanther's Avatar
Thumbs down NOT GOOD AT ALL
Ok i just get home from being in CO for a week for some snowboarding action. I CANT wait to just get in my car and go drive when i finally get home.
I thought a grocery store run would do the trick.
I pull out of my neighborhood, 1st-2nd-3rd then to stop sign where im in neutral again. I pull out onto the street and as im going to 2nd, it grinds pretty badly. I had the cluth all the way down. Ok so i skip 2nd then go to 3rd. I cruise at 4th for a bit and when i downshift to go into the parking lot i find that i CANT shift into 2nd.
Thats right, the shifter knob would NOT stay in 2nd. I would depress the clutch completely, put the knob securely into 2nd, then start to let off clutch. Right after i start letting of the clutch it grinds and pops me back to neutral. It does this EVERY time.
I limp home and try to get into 2nd. I guess i perfectly rev matched going from 1st gear and it slipped into 2nd. NOW IT WONT LEAVE 2nd GEAR.
Its STUCK in 2nd gear. I tried getting it into neutral with the car on AND off, reving and not reving.
Excuse me, but what the ****. Im easy on the car, it has mainly highway miles.
I have a 2006 Civic Si manufactured in June of 2006. 8000 Miles with dealer changed oil twice already.
MrPanther is offline   Reply With Quote
Old 11-28-2006, 01:52 AM   #2 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Yeah, that doesn't sound good at all. I'm not well versed in manual transmissions, but I'd say you're screwed. All I can say is bring it in to the dealer to get it fixed. Cross your fingers and hope for the best.
Old 11-28-2006, 02:06 AM   #3 (permalink)
MrPanther's Avatar
Ill really be screwed if it is deemed not to be under warranty. I guess i will find out how much Honda really is worth when I go by the dealer tomorow. Did i mention ill be riding to that dealership following a f****** tow truck?
I have only mis shifted going into 2nd maybe four or five times, as in i didnt have the clutch all the way down those times. But for a brand new honda, especially one geared for agressive driving, to mis shift a few times and wind up with an undrivable car seems like madness to me.
Old 11-28-2006, 02:08 AM   #4 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
From what you described, it'll be covered under warranty.
Old 11-28-2006, 02:16 AM   #5 (permalink)
Torredo's Avatar
i had a car that did this same thing a few years back,
although it was not a civic it popped out cuz of a
retarded plastic slider...YUP!! a POS plastic part inside
a Trans???
Torredo is offline   Reply With Quote
Old 11-28-2006, 02:30 PM   #6 (permalink)
a Trans???
You would be shocked as to how much plastic car mfg'ers are using in trannies and on parts of the engines etc.
Old 11-28-2006, 03:02 PM   #7 (permalink)
CivicWithNav's Avatar
2nd gear sux ass dude...
Old 11-28-2006, 07:34 PM   #8 (permalink)
MrPanther's Avatar
Ok so I called Honda America. They asked what dealership I bought it from and put me on hold. A lady took me off hold and gave me a number to call for a tow truck. She informed me this is what my dealership uses and that it will be free of charge. One hour later my car was on its way to the dealership with me and a friend following it.
So I talked to the guy at the service desk and he said they will look at it first thing in the morning and that I will be granted a rental car if it is deemed to be under warranty. Ill find out tomorow, wish me luck.
Old 11-28-2006, 07:41 PM   #9 (permalink)
nofd1977's Avatar
Good luck dude! I always have trouble with them dealership people.
nofd1977 is offline   Reply With Quote
Old 11-28-2006, 07:45 PM   #10 (permalink)
damn that sucks i prolly woulda just kicked it with my foot to get it out of 2nd. and if i break something i'll just tell them i don't know what happened.
Old 11-28-2006, 08:09 PM   #11 (permalink)
urge31121@hotmail.com's Avatar
That sounds like a warranty repair...may be in the shop for a few days though. I'm guessing you'll have to have second gear replaced or possibly a new transmission but your new Si should not be having these problems already. I had a similar problem with my first new car, my 2001 Ford Mustang had to have fifth gear totally replaced within 12K miles or so. Don't worry though, Honda should fix it free of charge...it sounds like bad parts or poor assembly, not driver wear and tear. Good luck
urge31121@hotmail.com is offline   Reply With Quote
Old 11-28-2006, 08:39 PM   #12 (permalink)
hoanger's Avatar
Jason
you know what, i have the similiar problem and i posted it.
a few days ago, i was in 5th cruising... approaching a stop light so i try to downshift to 4th and IT WONT GO IN.
its stuck either in neutral or it can go back into 5th. scary as hell.
my clutch is all the way down, im trying to shift but nothing works. when its in neutral, it doesnt even move freely from left to right.
i sit with the hazard lights until it lets up again, it happened like 5 times that day and not once since.
i had my girlfriend sit in the car and shift gears while i took a look at the cables and stuff in the engine bay, and nothing was blocking it.
so i took it in to honda yesterday for them to check it out, they had it for a good 3 hours, put 100KM on it and called me to say they couldn't find anything wrong with it. they predicted its the cold weather cause we just recently dropped to a record low of -40 degrees celsius with the windchill. they said it might be my driving habits too... but i cant think why it would be the weather or the way i drive. maybe a rock got stuck in something?
try the dealership too.
hoanger is offline   Reply With Quote
Old 11-29-2006, 12:21 AM   #13 (permalink)
MrPanther's Avatar
You have no idea what I wanted to do. Im 19 and im paying for every cent of the car with a semi full time resteraunt job. I wanted to just attack the service guy when he said they would let me know if it was under warranty, I'm not taking this lightly, if its deemed not under warranty look for me in the Memphis papers, lol.
Old 11-29-2006, 01:46 AM   #14 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
Eeeep. The beloved 2nd gear is gone? wTf is wrong with 2nd & 3rd gears holy crap...
Old 11-29-2006, 02:15 AM   #15 (permalink)
MrPanther's Avatar
Yeah, the only thing that could be said is good about this situation is the fact that the gear stick is completely stuck in 2nd gear. This forces the dealership to tell me why and what happened to the transmission. With the 3rd gear slippage they can say there arent an obvious problems. They cant say that if its compltetely stuck.
Anyways yall, Ill let you know what they tell me tomorow.
Old 11-29-2006, 11:49 AM   #16 (permalink)
taste's Avatar
Good luck with this Bro. Keep us posted.
taste is offline   Reply With Quote
Old 11-29-2006, 12:24 PM   #17 (permalink)
Jennifer
Good luck with that. Don't let the dealership get all shady, that should definitely be covered.
jennerz22 is offline   Reply With Quote
Old 11-29-2006, 01:28 PM   #18 (permalink)
jaker's Avatar
It's probably a good thing you didn't kick it out of 2nd!!
jaker is offline   Reply With Quote
Old 11-29-2006, 04:03 PM   #19 (permalink)
MrPanther's Avatar
Well I called today at about 1 PM Central. They said they would call me back..
Well F*** that, I'm going up there after I get out of my next class, at around 3:30, they cant as easily blow me off when Im there in the flesh.
Old 11-29-2006, 04:11 PM   #20 (permalink)
cojaro's Avatar
In the paper, assuming that Herenton doesn't to anything stupid...
wait...
Nevermind, he never does anything. Ever.
You'll be in it as long as the cops don't hit another woman crossing the street.
cojaro is offline   Reply With Quote
Anyone but a drop in HID Kit in???? How is the Cut off? Is Xetronic HID a good brand coach2fast Lighting, H.I.D.'s, & Neon 9 12-06-2007 12:36 AM
What makes a good driver? vicSi Autocross & Sanctioned Drag Racing 6 09-30-2006 02:07 AM
Do you guy Feel the AEM cold-air intake is safe and good to do? ? ? ? coach2fast Garage 2 06-25-2006 03:51 PM
parking under a pine tree in 90 deg not good damb Detailing 7 06-18-2006 02:03 AM
Will the Si be good for Auto-crossing? Silver8th Civic SI 10 12-31-2005 12:41 AM
