Old 11-22-2006, 04:48 PM   #1 (permalink)
1twojay's Avatar
5w-50 Engine Oil
Well its time for my oil change, and i've been considering what kind of oil to get this time.
First of all, the climate is much warmer here compared to the states, so keep that in mind. And my engine is K20 non-si.
I've asked around and I've seen people use anything between 5w-30 to 5w-50. I know you guys use 5w-30 with the Si's, but alot of mechanics here have said that it's too thin for our climate, and that it will start dying around 3-4000km.
Anyways i got a bottle of AGIP 5w-50, better heat protection, good for high RPM's. But it seems you guys are running fine on 5w-30 so i'm a bit afraid its going to be too thick??
I havn't changed it yet, so i'm thinking if I should run 5w-30 instead. Any suggestions?
1twojay is offline   Reply With Quote
Old 11-23-2006, 05:15 PM   #2 (permalink)
Robare's Avatar
I would still go with 5w30 (I always go with what the manufacture suggest) ..... and do synthetic (pref to Mobile 1) if you can .....5w50 will be fine to..Either way you will be just fine in your environment IMO
Robare is offline   Reply With Quote
Old 11-25-2006, 11:17 PM   #3 (permalink)
moxom's Avatar
Sticking with the recommended grade/viscosity is always the best thing from a warranty point of view. However, a 5W-50 is a thicker viscosity than a 5W30 and will be will be just fine in the Si and will provide better protection in a warmer climate.
moxom is offline   Reply With Quote
Old 11-25-2006, 11:39 PM   #4 (permalink)
UncleSid's Avatar
Sid
AMSoil ftw!!! this study is of motorcycle oils...but its all the major brands...and im sure they are pretty close to the car oils...
http://www.performanceoiltechnology....aper_g2156.pdf
UncleSid is offline   Reply With Quote
Oil Change DIY ethlar Engine 251 12-01-2008 10:46 PM
2006 Civic Engine: I-VTEC webby Garage 8 10-16-2007 12:54 AM
2006 honda world news webby Garage 0 07-25-2005 10:31 AM
