Old 11-18-2006, 04:52 PM   #1 (permalink)
Robare's Avatar
Question 06 SI..After reflash cold start
I had my SI reflashed a few months back and the cold start hesitation was drastically reduced......It seems that with the colder weather the hesitation is back to the way it was before the reflash.....Anyone else experiencing this?
Robare is offline   Reply With Quote
Old 11-18-2006, 05:03 PM   #2 (permalink)
dREsTrUcTiON's Avatar
I'm having this issue as well.
dREsTrUcTiON is offline   Reply With Quote
Old 11-18-2006, 05:28 PM   #3 (permalink)
06civicsiguy's Avatar
matt
cold start
My Si was having hesitation starting. i tried a few things diff gas and fuel levels above 1/2. but nothing heard there was a ecu reflash for rpm hang and rpm hestation when driving in 1st gear. I did the ecu reflash. its a joke did nothing, actually made my car slower. vtec doesnt pull as hard as it did b4.
06civicsiguy is offline   Reply With Quote
Old 11-18-2006, 05:32 PM   #4 (permalink)
Jester FPS's Avatar
let the car warm up for a maximum of 30 seconds, drive around keeping rpm's below 3K as much as possible allowing the engine to warm up.
once the engine is warmed up (having all blocks filling up half of the temp monitor) let her rip!
problem solved.
Jester FPS is offline   Reply With Quote
Old 11-19-2006, 04:21 PM   #5 (permalink)
problem solved.
This post explains everything. Don't let her idle too long - that does more damage than good because the engine stays cold longer.
Old 11-19-2006, 04:29 PM   #6 (permalink)
kuziken's Avatar
ummm....so you are saying that if i let my car at idle for 5 minutes before moving then that hurts the car....i dont believe this
kuziken is offline   Reply With Quote
Old 11-19-2006, 06:48 PM   #7 (permalink)
It doesn't hurt the car, all it does is waste gas. Idle for no more than 1 minute, then just drive it slowly until it warms up to full temp.
cold start - high rpm in idle kymecs Mechanical Problems & Technical Chat 42 07-19-2008 11:30 AM
Half-decent S2000 Start Button Install J-Ro Do It Yourself Articles 26 02-09-2008 07:17 PM
cold start.. Skyline4life Civic SI 10 09-20-2006 09:26 AM
Stumbling start? DigitalAnalog Mechanical Problems & Technical Chat 2 07-31-2006 06:46 PM
