Help!!! Transmission problem - 8th Generation Honda Civic Forum
Old 03-14-2010, 12:53 AM   #1 (permalink)
I was driving my 2006 auto civic coupe and it started to have trouble shifting into second. I parked the car and checked the transmission fluid and it was fine. I then started the car back up and the check engine light came on and the "D" green light is blinking. Do you know what could cause this? My car only has 38,500 miles on it. Should I drive it to the dealership (10 miles away) or should I have it towed. Would this fall under the power-train warranty?
Thanks,
Mikehenryjr is offline
Old 03-14-2010, 01:10 AM   #2 (permalink)
yes, bring it to the dealership...it falls under the power train warranty
franciscongs is offline   Reply With Quote
Old 03-14-2010, 01:15 AM   #3 (permalink)
I am not sure if we should drive it or have it towed? I do not want to cause damage.
Mikehenryjr is offline   Reply With Quote
Old 03-14-2010, 01:57 PM   #4 (permalink)
Anyone?
Old 03-14-2010, 02:25 PM   #5 (permalink)
when you try to drive it, does it shift? is the problem all the times or just intermittently?
Possible Transmission problem. Help? bassmastercivic09 Mechanical Problems & Technical Chat 2 01-17-2010 06:49 PM
transmission problem =( BlkFA5 Mechanical Problems & Technical Chat 7 07-07-2009 05:12 PM
transmission problem spammy123 Mechanical Problems & Technical Chat 4 11-28-2007 08:43 PM
transmission problem? marksi07 Mechanical Problems & Technical Chat 4 11-01-2007 08:39 PM
Transmission problem ryryninja Mechanical Problems & Technical Chat 8 02-27-2007 02:37 AM
