The engine idling is too significant - 8th Generation Honda Civic Forum
Old 03-12-2010, 09:54 PM   #1 (permalink)
The only thing I've done to my car is removing exhaust resonator, and adding a CT-Engineering intake. When the car is stopped and idling it makes ticking noises and the vibration(idling) is too significant that the heat shield from CT-E intake shakes. I was wondering if this was normal or is there something wrong with it?
Help!!!!!!!!
djynk is offline
Old 03-12-2010, 11:00 PM   #2 (permalink)
Any 1?
djynk is offline   Reply With Quote
Old 03-12-2010, 11:04 PM   #3 (permalink)
Vee Easy
did you reconnect all the tubing and wiring into the intake ?
Follow me on InstaGram , vee2easy
Tough times don't last but tough people do
Strate L O S S is offline   Reply With Quote
Old 03-12-2010, 11:09 PM   #4 (permalink)
db8typer's Avatar
Re: The engine idling is too significant
Any CEL's?
Sent from my iPhone using Tapatalk
db8typer is offline   Reply With Quote
Old 03-13-2010, 02:14 AM   #5 (permalink)
No CEL, and CT-E intake uses stock intake tube, so I didnt even bother to touch it in first place.
Old 03-13-2010, 02:56 AM   #6 (permalink)
Da KLEEN WUN!
Where is it idling at cause normal is 800rpm. Idle might have changed a little cause more vibration but shouldn't harm anything.
KleenZ3 is offline   Reply With Quote
Old 03-13-2010, 07:35 AM   #7 (permalink)
Yea idling is at around 800 rpm. So i should not be worried?
Old 03-13-2010, 10:31 AM   #8 (permalink)
02civicsi's Avatar
Location: Seeing the beauty of the world in a drop of morning dew
I am the Juggernaut!!!
Did you do a an idle re-learn after installing the intake?
02civicsi is offline   Reply With Quote
Old 03-13-2010, 02:16 PM   #9 (permalink)
YEA. After installation, I let it sit there for 10 min.
Old 03-13-2010, 02:33 PM   #10 (permalink)
Da KLEEN WUN!
Probably nothing to worry about...you just need to get use to it. It felt totally different when I installed my intake and headers and cut off my resonator all in one day. Now it doesn't bother me
Old 03-13-2010, 02:40 PM   #11 (permalink)
Cool. Thx for replies guys.
Old 03-13-2010, 02:45 PM   #12 (permalink)
asianskater91's Avatar
david
if your ac is on or even your air is on it will cause the motor to work harder and cause stuff to vibrate btw
asianskater91 is offline   Reply With Quote
Who says sedans cant kick ass too? R18 --- the little engine that could millerman Civic Coupe And Sedan 60 03-13-2010 05:44 PM
engine idling fluctuations ktowncivic I.C.E., Electrical, Security, & Navigation 1 04-30-2009 02:50 PM
Idling vs Engine off wing_gundam Garage 27 11-13-2008 03:46 PM
Engine oil, is this too dark? Gonzo Mechanical Problems & Technical Chat 20 02-04-2008 01:36 AM
Idling too high VoLTr0n Mechanical Problems & Technical Chat 19 07-02-2006 02:41 AM
