#42 (permalink) |
Thanks to the 8th Civic community, I was going to blame my new K&N drop-in air filter because the problem started some time after the filter was put in. (I thought the oil on the filter may dirty the sensor or something)
For me, the symptom occurs when all the conditions (listed below) are met. The engine is in well within the operational temperature. The car is in motion at slow speed. The gear is in neutral. RPM range between 1100 – 1300. <<< anyone else notice this? (Hope this verifies that we have the same problem) I began to notice the problem 5600+ miles later. Meanwhile, I had the ECU update from a dealership (not the Hodata refresh) at 4900 miles and K&N drop-in filter put in at 5600 miles but nothing else. (oh, and the oil-changes) Honda really needs to perfect their DBW engineering soon because this DBW never has been the “greater throttle response” instead, one big “Annoying response” for me. |
#45 (permalink) |
I HATE Stephanie
Edit:
I think this is more of a recall for a bad gas pedal installation which causes delay on throtle response and if come loose then throttle becomes stuck thus having no acceleration which ccould cause an accident must be something similar tot his bulletin NHTSA Campaign ID Number: 05V509000 - Hide Details Recall Date: 11/03/2005 Component: 2006 HONDA CIVIC VEHICLE SPEED CONTROL:ACCELERATOR PEDAL Potential Units Affected: 25298 2006 HONDA CIVIC VEHICLE SPEED CONTROL:ACCELERATOR PEDAL Recall Date: 11/03/2005 Summary: CERTAIN PASSENGER VEHICLES, THE PEDAL WERE NOT PROPERLY INSTALLED AND MAY COME LOOSE AT THE FLOOR MOUNTING. Consequence: IF THE ACCELERATOR PEDAL IS NOT INSERTED PROPERLY, THE PEDAL CAN COME LOOSE FROM THE PEDAL STOPPER CAUSING THE THROTTLE TO BECOME STUCK INCREASING THE RISK OF A CRASH. Remedy: DEALERS WILL RESET THE PEDAL OR REPLACE THE WHOLE ASSEMBLY FREE OF CHARGE. THE RECALL BEGAN ON NOVEMBER 14, 2005. OWNERS MAY CONTACT HONDA AT 1-800-999-1009. Potential Units Affected: 25298 Notes: HONDA CIVIC P98 Last edited by striker_1818; 12-06-2006 at 02:29 PM. |
#46 (permalink) | |
#47 (permalink) | |
if you want to come over here and drive my car the problem is NOT normal the throttle is completely dead you have to hold the pedal about 1/2 way down for 1-2 seconds for the ecu to open the throttle now tell me this is normal? if you joined here to bash on everyones responses i suggest they you leave ASAP! |
#48 (permalink) |
I explained the service bulletin to you. I never said anything about you or your cars problems. The dealer cant just pull an ecu reflash out of the air and use it on your car. If there isnt an update, THERE IS NOTHING THE DEALER CAN DO!! You will have to wait until Honda provides us with the required fix, ECU reflash or otherwise. Dont start spouting off about how horrible the dealer is when there isnt anything that they can do.
#51 (permalink) | |
#54 (permalink) |
I want to revive this. I'll have someone from AHM to look at this thread. It's happening to me and no one didn't know what I was talking about until I let my buddy drive my car today. You can hear him bleeping on the throttle with his foot but no response! Ditto on the dangerous part. VERY dangerous!
#55 (permalink) |
Well, now that it's almost summer, I've become used to it although it has caused me to almost stall in some situations.
I still believe it needs to be addressed. Maybe the reason other people aren't experiencing is because they drive their car normal. I like to blip the throttle while downshifting, and thankfully the revs match easily. -D |
#56 (permalink) |
Si civic... I like to blip too...
And this delay really puts a damper on our fun. Ihave to come to a COMPLETE stop to get the sounds I want. At least we get to sound cool when we start on a little incline... u know what I mean. Im probably going to be working at honda this summer and I am good friends with the owner. So , I will try to get to the bottom of this so we can blip-the-hell-out-of-it at any speed/time. At least we can still enjoy the sound of perfectly mathched downshifts. |
| 33whp and 30wtq from hondata reflash and DCRH!! | 06redsi | Civic SI | 140 | 03-30-2008 01:26 AM |
| Window Problem | waross | Mechanical Problems & Technical Chat | 14 | 12-17-2007 05:27 PM |
| throttle hesitation on 06 Si | kingcivic06 | Mechanical Problems & Technical Chat | 3 | 03-19-2007 08:37 PM |
| Problem with Pioneer P880PRS install | nuked99 | I.C.E., Electrical, Security, & Navigation | 2 | 11-13-2006 12:24 AM |
| Just a thought about our throttle body | legendman | Civic SI | 12 | 10-02-2006 02:12 PM |
