#25 (permalink) |
mine does the same thing. it kinda sucks it happens when i'm at a light and then i give it a little gas and come off of the clutch, just to get rolling, then press the clutch again and try to rev and it doesn't rev up it just cruises in neutral. i know it's the DBW b/c in any other car w/o DBW u can do the same thing and the engine will rev when u press the gas.
#26 (permalink) | |
1) rev hang 2) throttle delay @ idle 3) spring-sound rattle behind CD player 4) engine won't rev past 10,000rpm jk #4 Darryl |
#30 (permalink) | |
#31 (permalink) | |
#33 (permalink) | |
#34 (permalink) |
Umm, I don't think you all should be confusing the "rev-hang" issue with this problem here. This seems to be a whole different problem altogether. I have the rev-hang problem past 3500RPM and also have slightly delayed throttle response (most likely due to the DBW engineering) but have yet to encounter the problem you all are having where the car does not rev at all when in neutral.
Can someone elaborate a bit more on the cause of the problem? What exactly do you do to cause the symptoms to occur. When I first got the car, I would double-clutch on downshifts just to learn how to do so and have now resorted to just normal downshifts. I never experienced the problem that you are having. However, I have noticed sometimes that while coasting in neutral and let the RPMs drop to the normal idle (preparation for a 3rd gear turn), when I shift into third gear, give it gas and let the clutch out, there are times when I seem to completely miss rev-matching and make the car jerk. Now, I attributed this to driver error since I'm still fairly new to driving stick; however, I have done these types of maneuvers before and have done some nearly flawlessly. Perhaps it could be that the engine is not revving at all when I give it gas? I'll still stick to driver error being the cause but I'll go check it out later and see if my revs truly aren't going up. |
#35 (permalink) |
^ ok. Sweet example: First gear, in the snow going about 5 km/h. I blip the throttle like 10 times. Nothing. In other cars you would hear the intake "whooshing", but in my Si, nothing, no revs. This is dangerous IMO.
My car has no problem rev-matching when downshifting, this seems to only occur at idle and/or slow speeds; speeds when making turns I have no throttle input.
#36 (permalink) | |
In fact, I'm gonna go to the dealer right now and see what they say...argggg... |
| 33whp and 30wtq from hondata reflash and DCRH!! | 06redsi | Civic SI | 140 | 03-30-2008 01:26 AM |
| Window Problem | waross | Mechanical Problems & Technical Chat | 14 | 12-17-2007 05:27 PM |
| throttle hesitation on 06 Si | kingcivic06 | Mechanical Problems & Technical Chat | 3 | 03-19-2007 08:37 PM |
| Problem with Pioneer P880PRS install | nuked99 | I.C.E., Electrical, Security, & Navigation | 2 | 11-13-2006 12:24 AM |
| Just a thought about our throttle body | legendman | Civic SI | 12 | 10-02-2006 02:12 PM |
