Old 11-15-2006, 08:33 AM   #1 (permalink)
ABS warning on
my ABS Warning is on....
tried to searhc here but no answers yet
is there a way to bring it back to normal (not like going to the dealer):)
toyapogi is offline
Old 11-15-2006, 09:04 AM   #2 (permalink)
CivicWithNav's Avatar
what!?
go to the dealer...
1)it's safety hazard
2)it's under warranty
CivicWithNav is offline
Old 11-15-2006, 10:13 AM   #3 (permalink)
The Orignal CivicPC
ohiocivicracer's Avatar
Kevin
ya mine came on like 3 weeks ago, i took it in, and it was something with my seat... honda told me they already did a recall on it, then 2 weeks after they fixed it, i got something saying there could be defective with my airbags and abs and to bring it in, so i called and they were like o, thats what we did already...
hmm i dunno my dealership is lame and doesnt like to do things right or at all...
FIJI Crew # 3
The Original 8thCivicPC
ohiocivicracer is offline
Old 11-15-2006, 12:57 PM   #4 (permalink)
you don't have a choice, bro. its a safety issue so u have to bring it in.
themuse03 is offline
Old 11-17-2006, 09:46 AM   #5 (permalink)
I've fixed it... my abs wire has been cut, from a tree branch
so i removed the right rear abs sensor and connect the wire
toyapogi is offline
Old 11-20-2006, 01:42 PM   #6 (permalink)
You fixed it?
I somehow doubt that removing one ABS wheel sensor is what I would consider a fix. Why are people always trying to avoid a trip to the dealer to repair a safety issue..under warranty no less? What you have done, if I read it correctly, is disable an ABS sensor to one of four wheels. The ABS now cannot read the fact that one of your wheels is locked up and sliding and cannot administer anti-lock braking to that one wheel. In addition to this being a poor attempt at a home fix to a complex system it may also be UNSAFE and you may find out just how unsafe the next time you need the help of ABS. My advise is get it fixed correctly.
targettuning is offline
Old 11-20-2006, 01:45 PM   #7 (permalink)
OK I get it...
I re-read your post(once again) and I believe you state you removed the sensor..attached or re-attached the wire then replaced the sensor. If so good, if not, above post applies.
"Check Fuel Cap" - Merged Threads HardBoiler Mechanical Problems & Technical Chat 108 08-15-2008 02:22 PM
Can you turn off the Seatbelt warning beep? Dax I.C.E., Electrical, Security, & Navigation 15 10-12-2007 11:37 AM
Random abs light or is the bodyshop hiding something? gbae007 Mechanical Problems & Technical Chat 2 11-03-2006 12:02 PM
I love ABS and my Performance All Season's! wing_gundam Garage 1 10-22-2006 08:37 PM
ABS Behavior? DSchrag Mechanical Problems & Technical Chat 4 06-19-2006 05:37 PM
