High Speed Rubbing Sound - 8th Generation Honda Civic Forum
Old 03-11-2010, 06:31 PM   #1 (permalink)
Albrecq'sSI's Avatar
Seanzie
So my friend has a gd3. When he's going over 30 mph and turning left..just a gradual left turn going down the road or on the freeway..he hears a rubbing sound coming from his front left tire. He has stock wheels and stock suspension and it only happens at higher speeds. Anyone have a clue of what it could be?? Thanks in advance
Albrecq'sSI is offline
Old 03-11-2010, 10:57 PM   #2 (permalink)
07TWFA5's Avatar
is the fender line loose? i had that rubbing sound before when i turned left and it was cause my fender line was loose.
07TWFA5 is offline   Reply With Quote
Old 03-12-2010, 07:18 AM   #3 (permalink)
JFoss's Avatar
Jeremy
Does the sound go away if he turns back right? Sounds like a wheel bearing to me.
JFoss is offline   Reply With Quote
Old 03-13-2010, 12:53 AM   #4 (permalink)
Seanzie
The fender liner is cool I checked that. The sound is not present when he turns right only left. So yes, it disappears when he finishes the left turn and goes straight again
Albrecq'sSI is offline   Reply With Quote
Old 03-13-2010, 10:47 AM   #5 (permalink)
JFoss's Avatar
Jeremy
Sounds like a text book wheel bearing. GL
Tired of that Sunroof creak or rubbing sound over bumps? fiji06si13 Exterior Style Mods 79 02-07-2012 01:28 PM
Vibration on High Speed civiclx07 Mechanical Problems & Technical Chat 15 08-27-2008 04:14 PM
high speed question Dan1981 Wheel And Tire Upgrades 2 05-10-2008 12:28 AM
High speed memory Tommygun43 Photography 6 07-31-2007 09:39 AM
Cool High Speed Videos webby Water Cooler 9 06-14-2007 01:44 AM
