Third gear not fully engaging/popping out...
I'm relatively new to Honda, and I hope I'm not bringing up a worn-out issue here, but prior to purchasing my 07' Si, I was driving my brother's 05' RSX Type-S I noticed that when the car is still somewhat cold, it wouldn't completely shift into third gear, and the shifter would sort of pop out. Basically, I really had to make sure it was in third before letting off the clutch. I brought this issue up to my brother, and he basically mentioned that Honda's/Acura's have basically developed a reputation for this, so I didn't think much of it.
When I bought my Si, RIGHT OUT OF THE DEALERSHIP, it popped out of third the same way on the RSX. I've had the car for about a month now, and it's happened two other times, but it's grinded those times because I let off the clutch without realizing it wasn't fully in third. Is this naturally occurring on the tranny, and I should just make sure it's all the way in third, or should I bring up this issue with the dealer? Thanks in advance. :) EDIT: N/M, posting this thread yielded one in which my question was basically answered. For some reason, and I feel silly mentioning this seeing as I am by no means new to message boards, I can't figure out where the delete thread button is. |
to acctually answer it, my si has the same problem. Sometimes i'll catch it because i can feel that it's not fully engaged adn i'll catch teh clutch movemnet right at the engagement point and just shove the shifter in.
I know this doesn't really help you right now, but yes, i'm experiencing it. |
#3 (permalink) | |
I'm sure if I just invest some extra concentration on third gear in particular, I can avoid any problems, but I'm not too fond of having to concern myself with something that I really shouldn't have to concern myself with in the first place. Last edited by Paradox Lost; 11-15-2006 at 03:30 AM. |
#5 (permalink) | |
its a prob that happens to almost all new civic owners that i known...i have talked to 4 si owners locally that all have the same prob in either 2nd or 3rd gear...i actually took my car back to the dealer to tell them about it, but they have no knowledge about it...so i dont know...
#10 (permalink) |
Resident Si Sedan Hater
Man, don't just gripe about on forums, take it to the dealer. I got my 3rd gear syncro fixed and it's pretty much fixed. Still a little notchy. My guess is the shift link also needs to be replaced, but I can live with that.
#12 (permalink) |
Sycnro's (i think thats how you spell it) needs to be replaced for third gear.
thats the fix for RSX but it will do it later down the road. There is another fix that usually fixes this issue, just flush out the tranny fluid with redline or royal purple. |
#13 (permalink) | |
#14 (permalink) |
i have the same problem. i'm taking mine in for service on monday. i'll let you guys know what happen. this is the second time i'm bringing it in regarding this problem. first time i brought it in, they didn't find anything, but it's got worse, so i'm taking it in again. and if i don't do anything about it, i'm afraid it'll get even worse.
#15 (permalink) | |
#18 (permalink) |
Okay, so I went ahead and sent it into the dealer today, although for a different problem. But I went ahead and had them check out the issue with third gear anyway. So I get a call from them a few hours later, going over the inspection, and regarding the tranny, my service provider asked if I had the transmission serviced. I said no, and he proceeded to tell me that whoever PDI'd the car when it first came into the dealership put in gear oil (I think he said gear oil) instead of transmission fluid, and that was causing the problem with third that I had been experiencing. Not only that, but they overfilled it, as well. So, it seems they think this is the root cause of my third gear problem.
Nevertheless, considering that so many others seem to be experiencing the same problem, and also that I experienced the same thing on the Type-S, I doubt this is the underlying cause- unless the same guy is running around putting the wrong type of fluid in everyone's Si and Type-S. So, we'll see what happens. By the way, the main reason I brought it in was for a strange creaking noise that seemed to be coming from my rear suspension, and it turns out that my rear passenger side shock needs to be replaced. |
#19 (permalink) |
i brought mine in as well, and this is the 2nd time i've brought it in for the same problem/complain. they still haven't found anything. they we're saying it could be the way i shift. i mean wtf? i've been driving for more than 10 years, so it's not my shifting. plus it only happens on 3rd gear and no other gears. also, they found the same "overfilled" transmission fluid in mine.
#20 (permalink) | |
| Has anyone takin their SI back to dealer for a notchy feeling 2nd gear yet? | 06redsi | Mechanical Problems & Technical Chat | 11 | 10-02-2007 02:37 AM |
| 3rd Gear... | nnorton | Civic SI | 21 | 01-13-2007 07:25 PM |
| For all you Top Gear fans.. Richard Hammond was in an accident. | dentrecords | Water Cooler | 48 | 12-14-2006 10:35 AM |
| Whistling Noise in 4th Gear | enter801 | Mechanical Problems & Technical Chat | 0 | 03-23-2006 08:29 PM |
