Old 10-02-2007, 02:04 AM   #141 (permalink)
jun00110010's Avatar
hmmm.. all these replies about gm synchromesh being really good for the car. well, i have royal purple mtf and it was good for the first 4 or 5k miles that it was on. then.. all hell broke loose and the popping out/grinding came back. so that poses another question: is the synchromesh any better in solving the problem or is it just a band-aid to the REAL solution?
i am so pissed off with third gear.. i think about it all the time even when i'm not in my car.
thinking about bringing it to the dealer tomorrow.. i printed out this service bulletin:
TSB - Technical Service Bulletins
Make : HONDA Model : CIVIC Year : 2006
Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.)
Service Bulletin Num : 1205
Date of Bulletin: DEC 16, 2005
NHTSA Item Number: 10018868
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
TRANSMISSION GRINDS AT SHIFTS, SKIP SHIFTING.
and the parts list for someone that got it fixed before:
1 23450-PNS-000 Gear
1 23444-PNS-306 Gear Set, Third
1 24210-PNS-010 Fork (3-4)
1 94109-14000 Washer, Drain (14mm)
Wish me luck! I'll be sure to let you guys know how it goes.
jun00110010 is offline   Reply With Quote
Old 10-02-2007, 03:15 AM   #142 (permalink)
nayilsi's Avatar
forget 3rd gear...
ive had more problems with 2nd gear.
Old 10-11-2007, 12:52 PM   #143 (permalink)
Royal Purple Synchromax and GM Synchromesh are a 0w10 weight fluid and is too light to be run in a daily driver. The Honda MTF has a viscosity of a 30weight oil. So if you are looking for something better run RP 5w30 motor oil or the Racing XPR 5w30. I ran that on the track for years and the lowest I would go was XPR 5w20 which use to be called Racing 11.
07-[ivi] is offline   Reply With Quote
Old 10-11-2007, 09:10 PM   #144 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
My gear grinding went away (3rd popping and 2nd gear grind) after Amsoil MTF Synchromesh was added. Then the 2nd gear grind @ high rpms came back. Dealership adjusted cable and it is gone.... FOR NOW...
2nd gear FTMFL
Has anyone takin their SI back to dealer for a notchy feeling 2nd gear yet? 06redsi Mechanical Problems & Technical Chat 11 10-02-2007 03:37 AM
3rd Gear... nnorton Civic SI 21 01-13-2007 08:25 PM
For all you Top Gear fans.. Richard Hammond was in an accident. dentrecords Water Cooler 48 12-14-2006 11:35 AM
Whistling Noise in 4th Gear enter801 Mechanical Problems & Technical Chat 0 03-23-2006 09:29 PM
