#101 (permalink) |
Maybe this will help it is straight from Honda.. I haven't had any problems with transmission on my 07 Si.
Stiff Shifting, Popping Out of Gear? Replace the MTF NOTE: This article applies to all M/T-equipped Honda cars and trucks. We’ve heard reports of customers complaining about the M/T shifting stiffly or popping out of gear. In each case, the M/T was using aftermarket MTF or old Honda MTF. If you’ve got a vehicle in your shop that fits this profile, try draining the MTF and replacing it with new Honda Genuine MTF (P/N 08798-9031, H/C 8429094). This new MTF offers better overall shift quality in cold weather (especially in freezing temperatures), and it’s got better friction reduction for improved fuel economy and longer transmission life. After filling the M/T with this new MTF, take a 10-mile test-drive around town so you can do a lot of shifting. If you’ve still got this problem after your test-drive, then it’s time to do some troubleshooting. |
#103 (permalink) | |
#104 (permalink) | |
This might be a stupid question but where do you find the officical honda bulletin's at? I've seen some posted here before but where do you guys find them at? |
#106 (permalink) |
I found this vague reference to a tranny issue for '06 Civic's. Doesn't say "Si" specifically, but looks similar to the discussion in this thread:
http://www.hondacivicforum.com/recal...d_1205/TSB.htm Does anyone know if this is a TSB for the '06 Civic Si tranny? Looking for (hoping for) a Bulletin # to tell my dealer when I go in to get my fluid changed... |
#108 (permalink) | |
Phantom Poster
![]() Join Date: May 2006
Justin aka Mr. JT
I have close to 15 K only happens when cold if it does happen car and it's virtually non existent now gets better as you drive......or is it driver adapts to the car......uh.....uh.....
#110 (permalink) | |
It also seems to me that earlier '06 Si's may have had their tranny overfilled at the factory. Mine was bought in April of '06 and I only have ~9200 miles so far (I work from home). If so, this is not a driver issue, and it won't get better over time (unless the fluid level somehow goes down to a normal level). Several have reported having too much fluid escape when they changed they're fluid. Also, ProspeedCTR has stated (above) that Honda has seen this complaint from customers and they recommend changing the tranny fluid to try and fix the problem. Of course, changing the fluid means they probably get the fluid level right, which may be all that's really needed (just guessing). Sometimes, topics discussed here are driver issues, but this doesn't seem to be one of those. |
#111 (permalink) | |
Phantom Poster
Justin aka Mr. JT
I had this problem it has gotten better. I might try changing fluid some time soon though for precautionary messures..... |
#115 (permalink) | |
#116 (permalink) | |
#119 (permalink) | |
AMSOIL Synthetic Synchromesh MTF 5W-30.
#120 (permalink) | |
| Has anyone takin their SI back to dealer for a notchy feeling 2nd gear yet? | 06redsi | Mechanical Problems & Technical Chat | 11 | 10-02-2007 03:37 AM |
| 3rd Gear... | nnorton | Civic SI | 21 | 01-13-2007 08:25 PM |
| For all you Top Gear fans.. Richard Hammond was in an accident. | dentrecords | Water Cooler | 48 | 12-14-2006 11:35 AM |
| Whistling Noise in 4th Gear | enter801 | Mechanical Problems & Technical Chat | 0 | 03-23-2006 09:29 PM |
