Old 12-17-2006, 10:12 PM   #81 (permalink)
cappykd's Avatar
Kirk
Originally Posted by si_civic
1st gear is fine, 2nd is fine. ITS JUST THIS STUPID 3RD that's peeving me off.
2006 Honda Civic
Bulletin #: 1205
Sequence #: 10018868
Date: 12/16/2005
Component Name: 102000 power train:manual transmission
Make: Honda
Model: Civic
Year: 2006
Summary: Transmission grinds at shifts, skip shifting. *
Of course, 2006's get the attention, like the reflash, 2007's DO NOT.
That was from 05. It's a year old.
cappykd is offline   Reply With Quote
Old 12-18-2006, 12:26 AM   #82 (permalink)
bboylocob's Avatar
BRENT
i just changed my mtf with the pennzoil synchromesh.shifting is alot smoother and less grinding and also no probls with 3rd gear anymore for me!!!!
bboylocob is offline   Reply With Quote
Old 12-18-2006, 01:03 AM   #83 (permalink)
BATANG CITY JAIL's Avatar
almost a month after changing my oil..3rd gear still behaving.
Old 12-18-2006, 02:26 AM   #84 (permalink)
SiRyan's Avatar
I just changed my MTF today with Gm Syncromesh Friction Modifier. I'll see how it is tomorrow.
SiRyan is offline   Reply With Quote
Old 12-18-2006, 03:30 AM   #85 (permalink)
^^ i was told that i should not do it with that GM syncromesh, i was thinkin about using that but i wonder whats the weigh and viscosity of that oil since in honda the replacement can be a 10w-30 oil.
anyway...tell us whats the changes..
Old 12-18-2006, 04:11 AM   #86 (permalink)
did you change it yourself? what oil did you use?
penguix is offline   Reply With Quote
Old 12-18-2006, 04:18 AM   #87 (permalink)
yes..i have a DIY somewhere in here... and i just use the "new" honda MTF...
Old 12-18-2006, 04:27 AM   #88 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
What weight is the GM syncromesh?
Old 12-19-2006, 02:26 PM   #89 (permalink)
NIGHTHAWKSI's Avatar
Ian
can some one please tell me how a different mtf is going to solve the gear problem? i dont understand if it is the fluid that causes the problem why wouldnt the rest of the gears be effected? i have the same problem as the rest of you but i am reluctant to bring it to the dealer because they have never solved any problem i have had with the car...they always just tell me that that cant hear/find anything wrong and then proceed to tell me about all the miles they racked up on the car. anyway...before i have to resort to the dealer, i will spend the money and change the fluid myself but i dont see how it helps....
Old 12-19-2006, 04:02 PM   #90 (permalink)
SiRyan's Avatar
OK, Since I changed my MTF with GM Synchromesh friction modified It shifts like SILK!!! No Grinds whatsoever and it goes in every gear like Margarine!! The Fluid doesn't feel as thick as the factory fluid and it is much easier and smoother to shift. It glides into every gear like if it has ice skates skating on ice!! I recommend GM Synchromesh FM to everyone that hasn't changed their MTF yet. It gets rid of the 3rd gear grinding issue. The first morning when I drove my car with the new MTF there was a tiny bit of notchiness still but throughout the day it felt like it was smothing out, by night time driving to my cousins house third gear felt like every other gear. No problems, No grinds whatsoever!!! Highly Recommended!!! Very easy to change. No more stress
Old 12-19-2006, 04:31 PM   #91 (permalink)
if you overfill your MTF it will put more load on the transmission gears and there is a posibillity that the other gears will also run even if they dont need too... and if you put not engough fluid, it will cause heat and more friction, then youll have problem in shifting, grinding more gears and maybe ended up on a broken syncro.
Old 12-19-2006, 04:35 PM   #92 (permalink)
don't take me wrong..but dont recommend it to them..let them choose and let them do the research on which fluid they think thats it good for thier tranny...
Old 12-19-2006, 05:41 PM   #93 (permalink)
cappykd's Avatar
Kirk
I agree. After research on the alternatives, I decided to change the factory fill with old MTF. Shifting was a little smoother. Then when the new MTF came out I changed it again and shifting is smooth as silk. Everyone should at least consider trying the new Honda MTF before trying an alternative.
Old 12-21-2006, 11:37 AM   #94 (permalink)
blackdragoon's Avatar
Jon
Ugh... so pissed! 3rd gear popped out/grinded on me 3 times in the past week!
I'm gonna try and bring it back to a stealership ASAP and get them to change my tranny fluid... sigh...
My poor baby...
blackdragoon is offline   Reply With Quote
Old 12-21-2006, 11:41 AM   #95 (permalink)
stevenshizzle's Avatar
Steven
I brought my car in and had nothing done. Honda was "unable the reproduce the problem". I'm thinking of getting some new tranny fluid for it, I'm wondering how much I need to fill it up with :I Anyone?
stevenshizzle is offline   Reply With Quote
Old 12-21-2006, 12:02 PM   #96 (permalink)
FG Two's Avatar
I had my trans fluid changed yesterday under warranty. They were unable to reproduce the problem, I think they shifted too quickly as it mainly does it when I am easy on it. They said they put the new fluid in it. 3rd is still not as smooth as the others but everything is alot smoother now. They said I need to let it work itself in for 2 weeks then give them a call.
FG Two is offline   Reply With Quote
Old 12-21-2006, 12:06 PM   #97 (permalink)
cappykd's Avatar
Kirk
Sounds reasonable. Well, the let it work itself in for 2 weeks part.
Old 12-21-2006, 12:08 PM   #98 (permalink)
Camry Loverz
AbsoluteGG's Avatar
Steven
Does this only happen to the SIs? I have an LX coupe and sometimes in third it doesnt go in and pops out but its only grinded once and first gear is hard to get into even when im stopped i have to release the clutch then press the clutch in again to shift in first.
AbsoluteGG is offline   Reply With Quote
Old 12-21-2006, 03:29 PM   #99 (permalink)
i brought mine in honda, cost me cost me 2qts. like $7.50
DIY somewhere in this forum...try search.
Old 12-21-2006, 08:21 PM   #100 (permalink)
Jon
Yeah, that gave me that same crap too. That's why next time I bring it in, I'm just gonna get them to change my MTF. I only have about 800kms on my car...
Has anyone takin their SI back to dealer for a notchy feeling 2nd gear yet? 06redsi Mechanical Problems & Technical Chat 11 10-02-2007 03:37 AM
3rd Gear... nnorton Civic SI 21 01-13-2007 08:25 PM
For all you Top Gear fans.. Richard Hammond was in an accident. dentrecords Water Cooler 48 12-14-2006 11:35 AM
Whistling Noise in 4th Gear enter801 Mechanical Problems & Technical Chat 0 03-23-2006 09:29 PM
