Old 12-14-2006, 02:31 AM   #61 (permalink)
Paradox Lost's Avatar
Rami
Yeah, it really seems that transmission fluid is essentially the culprit here.
I don't know if you guys had checked out the thread in the Si forum about Edmund's long term Si blog, but they've experienced the same problem, and made a note of it. Just scroll down a little to see that particular entry:
http://blogs.edmunds.com/roadtests/c...06HondaCivicSi
Paradox Lost is offline   Reply With Quote
Old 12-14-2006, 02:37 AM   #62 (permalink)
cappykd's Avatar
Kirk
I don't know if you guys had checked out the thread in the Si forum about Edmund's long term Si blog, but they've experienced the same problem, and made a not of it. Just scroll down a little to see the particular entry:
Honda wouldn't have gone through all the trouble to test and certify a reformulated Tranny fluid without a very good reason.
cappykd is offline   Reply With Quote
Old 12-14-2006, 02:44 AM   #63 (permalink)
Rami
Well, it looks like their ears weren't as def to the complaints of various customers as I may have thought (assuming they were inspired by this or an understanding of the general problem). The dealership flushed out my fluid (which wasn't even proper transmission fluid, according to them) a few weeks ago, and though it's shifting smoothly now, I wonder if they used the reformulated version of their factory transmission fluid.
Old 12-14-2006, 02:53 AM   #64 (permalink)
cappykd's Avatar
Kirk
Yeah I made a point to dump the old as soon as the new came out, I had to ask specifically for the new. Hopefully this will help or solve this issue.
Old 12-14-2006, 02:55 AM   #65 (permalink)
Not sure as to the hype surrounding this new Honda MTF (Acura announced an MTF reformulation as well, probably the same fluid); it may alleviate the 3rd gear problems as the Specialty Formulations' MTL-P did for me.
To whoever posted the question way before, the answer is yes, the SF-MTL-P is still shifting smoothly as the day I swapped the MTF.
But let's get something straight here, this is really bothering me:
USING A NON-HONDA FLUID WILL NOT VOID YOUR WARRANTY.
If you are using a transmission fluid that is API or SAE approved and is specified for use in your particular Honda transmission (similar viscosity, detergents, AW/EP additives, brass deactivators, etc.), then Honda Motor Co. must honor your warranty. The Magnuson-Moss Warranty Act, in a nutshell, states that the manufacturer cannot deny service based upon an aftermarket product that is used UNLESS the aftermarket product is provided to you free of charge.
"The federal minimum standards for full warranties are waived if the warrantor can show that the problem associated with a warranted consumer product was caused by damage while in the possession of the consumer, or by unreasonable use, including a failure to provide reasonable and necessary maintenance."
That is just one component of the Warranty Act. In a real-world application to automotive aftermarket products, it means that Honda can't deny coverage due to using a non-Honda product unless they can explicitly prove the aftermarket product caused the malfunction/damage due to improper installation, abuse, or incompatibility. It is the responsibility of HMC to prove the product caused the problem; you are not obligated to prove anything.
For example, I use SF-MTL-P in my transaxle, and let's say my synchros failed and I took the car to the dealer for warranty service. Provided my MTF has the necessary certification (which it does), is specified for Honda transaxles (which it is), and I have performed maintenance at the proper intervals (which I have), they must either repair/replace the transmission under warranty, or prove that the SF-MTL-P caused the synchro failure with factual evidence beyond a reasonable doubt. If in fact, Honda determines the aftermarket fluid itself caused the failure, the debate now becomes Honda vs. Specialty Formulations.
Information is your best tool. If any aftermarket product meets the criteria above, then the Magnuson-Moss Warranty Act applies. Make sure whatever fluids you use are API/SAE certified, or your argument is bust.
televascular is offline   Reply With Quote
Old 12-14-2006, 03:38 AM   #66 (permalink)
BATANG CITY JAIL's Avatar
i have'nt encounter any issue on third gear since i change my MTF, its been 2 weeks now...( crosses finger)
Old 12-14-2006, 09:19 AM   #67 (permalink)
UPDATE: smooth shifting with the new fluid. :-) "fingers crossed"
ADewan is offline   Reply With Quote
Old 12-14-2006, 09:22 AM   #68 (permalink)
SIcBoy's Avatar
jr
almost time for an oil change im going to get my tranni fluid changed
SIcBoy is offline   Reply With Quote
Old 12-14-2006, 10:25 AM   #69 (permalink)
cappykd's Avatar
Kirk
Great you use the aftermarket fluid and I'll use the Honda. Personally I trust the Honda fluid, it has nothing to do with Magnuson-Moss. It's actually the same reason why I'm using the HFP suspension. I trust Honda R&D and quality testing more than a third party. I'm positive that Honda tested their fluid in more Honda's and Acura's than SF did.
Furthermore why do newbs always get up on a soap-box about Magnuson-Moss. We've all seen the text of it before. You really don't need to qoute it for the 100th time in an effort to defend your decision to run SF MTF.
Old 12-14-2006, 10:51 AM   #70 (permalink)
stevenshizzle's Avatar
Steven
I just called Honda and scheduled an appointment for next week. The Navy Officer that I work next to laughed as he was listening to my conversation. I'd like to read about all of the malfunctions that have plauged the older Ford Mustangs. At any rate, I'll let you guys know what happens!
stevenshizzle is offline   Reply With Quote
Old 12-14-2006, 10:54 AM   #71 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
It's quoted to remind people that it is in their right to enforce this act. Big businesses, such as Honda, hide behind their legal counsel, thus it is important for you, the consumer, to know such acts exist.
I am going to contact Honda today, and if they act stupid about this new fluid, I'm going to get someone else (certified place) to change it with an aftermarket MTF.
Darryl
Old 12-14-2006, 10:58 AM   #72 (permalink)
cappykd's Avatar
Kirk
It's funny how everyone talks about enforcing the act but have you actually done so? As you said Honda will have lawyers and experts ready to testify if needed. Will You?
Old 12-14-2006, 11:29 AM   #73 (permalink)
cappykd, the point of the Magnuson-Moss is that you don't have to "testify" or anything of the sort. That's what the Act protects you from. And I'm sorry if my explanation was overused, I didn't realize others had clarified Magnuson-Moss before me.
And I relate with you completely on Honda's R&D. I, also, will use nothing but the HFP suspension because I'm not looking for something overly aggressive, and Honda quality is top notch as opposed to some shady aftermarket companies. I will use nothing but Honda OEM replacement parts for the life of my vehicle, except when it comes to fluids.
That being said, Honda does not engineer their own fluids. The MTF is not manufactured by Honda, but a third party that they contract to formulate fluids to their specifications. A balance between quality and profit margin must be met: they will give you good quality fluids (as I trust Honda to do), but it will not be as good as they can make it because large-scale manufacturing must stay cheap. I put Honda on a pedestal for their engineering prowess, but reducing costs is the name of the game in the auto industry.
Specialty Formulations, as an example, uses 100% PAO Group IV stock, with the proper additives for your Honda transaxle. It is a better MTF than the Honda fluid, because quality, not mass-market profitability, is their main concern.
And now I see what I've written and it seems like a rant.
Bob Is The Oil Guy.
Old 12-14-2006, 03:09 PM   #74 (permalink)
MaXaZoR's Avatar
I have a question to the people who change their transmission Oil over to the new blend. Was this covered under your warrenty or did you have to pay out of pocket for this? Also Honda has a TSB for the transmission 3rd gear grinding (TSB 1205 I believe). Does anyone have anymore infomation on this, such as what they give their Service Dept. Techs as a possible solution? The reason why I'm asking this is because I called up my dealership today to talk about this issue, 1st off they had no clue that a new oil fluid was released by Honda, then 2nd when I showed them the article, they told me that this wouldn't fix my issue w/ the third gear and if I wanted to swap the oil I would have to pay out of pocket for it. This just doesn't seem right to me.
MaXaZoR is offline   Reply With Quote
Old 12-14-2006, 03:12 PM   #75 (permalink)
cappykd's Avatar
Kirk
Some people have had it covered personally I was happy to pay out of pocket. I guess it depends on how many miles are on your car. I have 25,000 so it was time to change it anyway.
Old 12-14-2006, 03:26 PM   #76 (permalink)
MaXaZoR's Avatar
<--- Less than 5,000 miles
Old 12-17-2006, 07:01 PM   #77 (permalink)
not only is the OEM fluid crap, but get this, THE TRANSMISSION FLUID IS OVERFILLED AT THE FACTORY. This is evidenced by removing the fill bolt and observing a ton of fluid pour out (the fluid is supposed to be level to the fill hole, and as such none should come out if the car is level). This might have caused increased pressure inside of the transmission case.
Does anyone have a link/scan to this new TSB regarding 3rd gear? Anything yet on the 1st to 2nd grind at high rpm?
penguix is offline   Reply With Quote
Old 12-17-2006, 07:33 PM   #78 (permalink)
xmx250's Avatar
Maybe i should take my car in also. 350 miles and it has not grinded yet, but 3rd is definelty notchy, i have to push extra hard to get it in. However it hasnt grinded or popped out yet. Do you guys think i should take my car in and get the fluid changed before any more symptoms arise with my third gear?
xmx250 is offline   Reply With Quote
Old 12-17-2006, 07:52 PM   #79 (permalink)
Mondo1287's Avatar
Mine started doing it at about 2k miles, now it happens 3-4 times a week but I'm usually quick enough to catch it before it grinds.
Mondo1287 is offline   Reply With Quote
Old 12-17-2006, 09:32 PM   #80 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
1st gear is fine, 2nd is fine. ITS JUST THIS STUPID 3RD that's peeving me off.
2006 Honda Civic
Bulletin #: 1205
Sequence #: 10018868
Date: 12/16/2005
Component Name: 102000 power train:manual transmission
Make: Honda
Model: Civic
Year: 2006
Summary: Transmission grinds at shifts, skip shifting. *
Of course, 2006's get the attention, like the reflash, 2007's DO NOT.
Has anyone takin their SI back to dealer for a notchy feeling 2nd gear yet? 06redsi Mechanical Problems & Technical Chat 11 10-02-2007 03:37 AM
3rd Gear... nnorton Civic SI 21 01-13-2007 08:25 PM
For all you Top Gear fans.. Richard Hammond was in an accident. dentrecords Water Cooler 48 12-14-2006 11:35 AM
Whistling Noise in 4th Gear enter801 Mechanical Problems & Technical Chat 0 03-23-2006 09:29 PM
