Tranny problem! HELP! - 8th Generation Honda Civic Forum
Old 03-11-2010, 03:42 AM   #1 (permalink)
realxlai's Avatar
M. Bison
So after a year or so and 10K miles and 2 track days, 1 NA and 1 boosted(this past weekend) I think I may be experiencing oncoming clutch or master cylinder or whatever unknown transmission failure.. I have a Competition stage 2 clutch w/ 8lb flywheel
Experiencing:
I immediately experienced these things after leaving the track:
-1st gear notchyness which seems to be every other shift into first. Almost like the 3rd gear problem; push it into 1st and it needs more force so it kind of clunks through then sits into gear, sometimes wont even want to go in at all.
-Reverse goes in cleanly but sometimes won't want to come out.
-At the track the car absolutely would not get into 2nd gear for ****.
All the other gears shift perfectly though...
After bleeding the clutch and changing the MTF:
Initially on the ride over there before all that it felt very normal, no notchyness anywhere. After the bleeding and the fluid change it felt great but then on the way home the notchyness showed up again in first and a few times it was hard to get out of reverse.
Thoughts anyone?
realxlai is offline
Old 03-11-2010, 11:46 AM   #2 (permalink)
realxlai's Avatar
M. Bison
bump for help
realxlai is offline   Reply With Quote
Old 03-11-2010, 12:00 PM   #3 (permalink)
nycclaye's Avatar
Nick
wait, so did you notice any damage on the track?
nycclaye is offline   Reply With Quote
Old 03-11-2010, 12:21 PM   #4 (permalink)
realxlai's Avatar
M. Bison
What do you mean?
Old 03-11-2010, 12:35 PM   #5 (permalink)
Gillex572's Avatar
Gilles LeClair
How was it running on the track
Gillex572 is offline   Reply With Quote
Old 03-11-2010, 06:17 PM   #6 (permalink)
realxlai's Avatar
M. Bison
locked out of 2nd. shifting was tough in the other gears
Old 03-11-2010, 06:21 PM   #7 (permalink)
Rony
Dude I had all this symptoms in my si, all of them I had them. The first thing I did was to take out my short shifter then switch the clutch to exedy one and changed my tranny fluid to gm symchromesh and never had that problem again.
salvatruco2004 is offline   Reply With Quote
Old 03-11-2010, 06:30 PM   #8 (permalink)
realxlai's Avatar
M. Bison
Really? so it sounds like the master cylinder ing itself...
Old 03-11-2010, 06:38 PM   #9 (permalink)
Rony
Maybe but change your clutch and your clutch master cilynder at the same time
Old 03-11-2010, 06:40 PM   #10 (permalink)
realxlai's Avatar
M. Bison
thats what im thinking of doing. its like 80 bucks for a new OEM one.
Old 03-11-2010, 06:52 PM   #11 (permalink)
Rony
No get an aftermarket one in the future you going to have the problems
Old 03-11-2010, 07:46 PM   #12 (permalink)
realxlai's Avatar
M. Bison
aftermarket one is too intense.
Old 03-13-2010, 02:55 PM   #13 (permalink)
realxlai's Avatar
M. Bison
So it seems like its getting more intermittent but when it does get difficult to get into 1st or out of reverse it will be that way my entire drive. But when it doesn't happen its nice and clean the whole time...
That leads me to believe it might be temperature related probably and as the tranny gets hotter it starts locking me out of 1st.
tranny problem sicksi Mechanical Problems & Technical Chat 10 02-14-2010 09:59 PM
tranny problem HHondaZC Mechanical Problems & Technical Chat 4 04-08-2009 12:35 PM
Tranny Problem.. 08taffetawhite Mechanical Problems & Technical Chat 7 06-30-2008 06:50 PM
Help with Tranny Problem slostjoe Mechanical Problems & Technical Chat 16 11-03-2007 10:20 PM
Serious tranny problem Corpsman Water Cooler 11 11-04-2006 01:09 AM
