Check Engine Light - 8th Generation Honda Civic Forum
Old 03-10-2010, 04:06 PM   #1 (permalink)
Check Engine Light
On the way home from work today my check engine light turned on in my 2007 Civic (Automatic Transmission). A Honda dealership is on the way home from work, so I dropped in to ask them how much it would cost to see why the light was on.
$100.00 and an hour and a half in their waiting room just to see what the light was all about. I don't know why they felt like they needed to do such a thorough search rather than just tell me they'll check for codes for free. I give them business all the time for common maintenance. Is this common, or is this a poorly run dealership? I was going to take it to Autozone to get it checked out, but my brother-in-law has a code scanner and in 3 or 4 hours when he gets home from work I'm going to have him look for codes.
This is really stressing me out. I bought a Honda for its reliability and up to this point (47,000 miles), my 1997 Ford Taurus ran like a beauty.
AtlantaFalcon is offline
Old 03-10-2010, 04:20 PM   #2 (permalink)
Acorns!
webby's Avatar
are you out of warranty? If you are, they're going to charge you for service. A check engine light could be diagnosed for free at a autozone/pepboys, etc.
webby is offline   Reply With Quote
Old 03-10-2010, 04:24 PM   #3 (permalink)
I'm at 47,000 miles approximately, so I'm past the 3 years/36,000 miles limited warranty. I believe the drivetrain warranty is 5 years, 60,000 miles isn't it? I don't even know what a drivetrain warranty is. Thanks to forums like this I am learning little by little.
Charging me a little bit of money would have been understandable, but to charge me $100 to do a thorough search for an hour and a half (presumably) when they could at least try to scan for codes first, seemed a little off.
AtlantaFalcon is offline   Reply With Quote
Old 03-10-2010, 04:25 PM   #4 (permalink)
quickfit's Avatar
Resident asshat
what was the code for?
quickfit is offline   Reply With Quote
Old 03-10-2010, 04:27 PM   #5 (permalink)
I'm at about 47,000 miles, so my 3 year/36,000 miles limited warranty is over. My 5 year/60,000 mile powertrain warranty is still in effect, but I have no idea what that warranty covers. Thanks to forums like this, I'm learning little by little.
I would've understood a minor charge to check for codes at the dealership, but to only offer a thorough check of the engine for $100 for an hour and a half seemed like a bit of overkill.
Old 03-10-2010, 04:29 PM   #6 (permalink)
I don't have the codes yet. I'm waiting for my brother-in-law to get home from work. I'm going to go to his house to have him check. Maybe I should've just waited to post until then, but I'm nervous and wanted to ask the initial question about dealerships ripping me off. I get my routine maitenence done there all the time, but I think a change may be in order.
Old 03-10-2010, 04:33 PM   #7 (permalink)
quickfit's Avatar
Resident asshat
your your CEL should have been under teh 60k warrenty,
Old 03-10-2010, 09:27 PM   #8 (permalink)
Phil
The only thing the 5yr, 60,000 covers is internally lubed parts thats it. I am a service writer at a honda dealer and we charge $92 for diag on a cel. Now you can go to autozone or where ever and get the code, but they will not tell you exactly whats going on. If you get a code for evap leak tank side then what are you going to replace????? That's why when you pay the money they make sure your not wasting your money on throwing parts at it. Also did they tell you the diag time will get rolled into the cost?? My dealer does that, so in all reality your not losing the money.
vega66 is offline   Reply With Quote
Old 03-10-2010, 10:48 PM   #9 (permalink)
Yeah, they said whatever was wrong, the $99.95 would go toward the cost.
About an hour ago my brother-in-law pulled up the code. It was code PO420. Here is a little bit of information I found: P0420 - Check Engine Light Diagnostic Trouble Code Description
My brother-in-law reset the code and the check engine light is off for now. Is there any chance possible that it will stay off, or is it pretty much a given that the light will turn on again for the same reason soon? I've only driven about 2-4 miles since it was reset.
Old 03-10-2010, 10:57 PM   #10 (permalink)
hondagirl's Avatar
auto enginuity is an awesome diagnostic tool. It will pay itself I promise you should look it up.
hondagirl is offline   Reply With Quote
Old 03-11-2010, 03:32 AM   #11 (permalink)
Acorns!
webby's Avatar
You didn't mention if you have any aftermarket parts - header, exhaust, etc?
Old 03-11-2010, 06:51 PM   #12 (permalink)
Phil
DTC P0420: Catalyst System Efficiency Below Threshold.
Cats are covered for 8yrs or 80,000 miles so it should be under warr for ya.
Old 03-12-2010, 04:14 AM   #13 (permalink)
hondagirl's Avatar
unless he has a race header, That could also throw the cell
Old 03-12-2010, 10:28 AM   #14 (permalink)
Phil
very true
Old 03-12-2010, 10:57 AM   #15 (permalink)
gotsnodooks's Avatar
Russ
I'm guessing that since it an LX and the way he's describing the car...he's not modded. he's looking for reliability. Probably an O2 sensor went out on him.
gotsnodooks is offline   Reply With Quote
Old 03-12-2010, 12:30 PM   #16 (permalink)
SteveOFG2's Avatar
Steve-O
Give your OEM WBO2 a new lease on life try this before you go back to that dealer....and buddy if you are in a R18 and if the upstream it the problem diy save some money
SteveOFG2 is offline   Reply With Quote
Old 03-12-2010, 12:37 PM   #17 (permalink)
xrathy's Avatar
my car only has 7,000 miles and they still cant find the problem for the check engine light =p. Brought it to the dealership like 7 times already. Today is the 8th time its currently there right now, hopefully they find the problem today and get it fixed
xrathy is offline   Reply With Quote
Old 03-13-2010, 12:42 PM   #18 (permalink)
SteveOFG2's Avatar
Steve-O
take to someone with a code reader such as autozone and get the code and we can go from there
Old 03-13-2010, 01:33 PM   #19 (permalink)
xrathy's Avatar
already got code read all that stuff, its fixed now but yeah. Autozone and kraagen stop doing code checks cause its illegal
Old 03-13-2010, 01:45 PM   #20 (permalink)
SteveOFG2's Avatar
Steve-O
why is it illegal?
Check Engine Light - Tried everything, double check my install? Yodums Bolt-Ons And All-Motor 51 03-12-2010 11:36 AM
low rpm engine turns off check engine light on coy415 Intake & Spacer Discussion 5 11-04-2009 03:27 AM
check engine light on... NSPYR Mechanical Problems & Technical Chat 0 10-21-2009 05:35 AM
civic automatic(2007 lx) d light is blinking and check engine light on tigerboy0213 Mechanical Problems & Technical Chat 11 10-12-2009 09:45 PM
Check Engine Light On... I want it off t_rock_01 Mechanical Problems & Technical Chat 6 08-21-2008 08:47 PM
