HELP! Dip Stick reading/oil change 4.6qts - 8th Generation Honda Civic Forum
Old 03-09-2010, 09:37 PM   #1 (permalink)
08 Si sedan. Made the change to Amsoil 5w30. I put in exactly 4.6qts using a measuring cup on the money. I started the car and drove it for a short while. I let the car sit while I ate dinner. Checked the dip stick and its dead on the money at the lower dot on the dip stick...
Manual says if oil level is near or below the lower mark add oil...But I just put in exactly 4.6 qts....and it doesn't say where the oil level should be. PLEASE ADVISE
Tfin is offline
Old 03-09-2010, 09:43 PM   #2 (permalink)
yoooooo's Avatar
i usually put in all 5 qts and its perfect.
yoooooo is offline   Reply With Quote
Old 03-09-2010, 09:52 PM   #3 (permalink)
07civicsi_sc's Avatar
Scott
what you put in also had to fill up the oil filter, thats why its a little low
07civicsi_sc is offline   Reply With Quote
Old 03-09-2010, 11:06 PM   #4 (permalink)
You will need at least 5 quarts.
Ryan D is offline   Reply With Quote
Old 03-10-2010, 09:54 AM   #5 (permalink)
I know this...This isn't my first rodeo, but thanks for the tip. I did drive the car to circulate the oil and fill up the filter before I checked it.
Even with 5 qts it's still not to the top fill dot
Tfin is offline   Reply With Quote
Old 03-10-2010, 10:20 AM   #6 (permalink)
Scott
oh, my bad. im not sure then, 5 qts makes mine sit about perfect
Old 03-10-2010, 10:36 AM   #7 (permalink)
galaxygrey13's Avatar
Antonino B. B. Leyva
yeah i fill mines up with 5.
galaxygrey13 is offline   Reply With Quote
Old 03-10-2010, 11:30 AM   #8 (permalink)
Stephen
Mine is right at full with 5 quarts.
w00t692 is online now   Reply With Quote
Old 03-10-2010, 01:57 PM   #9 (permalink)
SteveOFG2's Avatar
Steve-O
are you parked on a slight slant?
SteveOFG2 is offline   Reply With Quote
Old 03-10-2010, 02:31 PM   #10 (permalink)
'06Siguy's Avatar
Scott
5 is where it's at.
http://www.8thcivic.com/forums/signaturepics/sigpic5287_4.gif
'06Siguy is offline   Reply With Quote
Old 03-10-2010, 02:47 PM   #11 (permalink)
ocdcivic's Avatar
Ray
Originally Posted by '06Siguy View Post
5 is where it's at.
+ about a quart in between changes.
ocdcivic is offline   Reply With Quote
Old 03-10-2010, 03:39 PM   #12 (permalink)
Thanks guys...I put the rest of the qt in last night to make it an even five qts. I'll check it tonight after the car has been parked a while and see what I get.
BTW I park in my garage..perfectly flat service...Thanks again y'all
Old 03-10-2010, 04:51 PM   #13 (permalink)
SteveOFG2's Avatar
Steve-O
10-4 buddy
Old 03-10-2010, 04:51 PM   #14 (permalink)
ojefferyo's Avatar
Jeff
5 qts is right at the full mark for me
ojefferyo is offline   Reply With Quote
Old 03-10-2010, 04:52 PM   #15 (permalink)
SteveOFG2's Avatar
Steve-O
^fixz the flash pro yet?
Old 03-10-2010, 05:06 PM   #16 (permalink)
ojefferyo's Avatar
Jeff
oh yeah, just reflashed the ecm with the new version of fp manager and it read the MAP sensor. gotta change the a/f ration sensor, car runs like ****zzz
Old 03-10-2010, 11:32 PM   #17 (permalink)
I have 2500 miles on my current oil change. I just checked the oil and the motor has not burned any oil. My SI only has 7000 miles on it though.
Old 03-11-2010, 03:37 AM   #18 (permalink)
Implosive_Disgorgence's Avatar
Erick
when i made the switch to synthetic oil i saw that it burns quicker than regular oil. i usually have to add a quart or so between changes aswell
Implosive_Disgorgence is offline   Reply With Quote
Old 03-11-2010, 06:20 PM   #19 (permalink)
Jo-Von-E
Geovone's Avatar
Jhovany M.
I've been wondering this as well.
When I went to pour my Mobil 1, I used 5 quarts.
After I poured it in, I read my dipstick and it was only to the first hole, the one farthest away from the handle.
So, I added almost half another bottle and that got me to the second hole, the one closest to the handle.
I thought I did something wrong since in the manual it says, use 4.6 quarts but I used 5.XX
Originally Posted by HeelsandEers View Post
^Give me a break.
Originally Posted by 2008slocivic View Post
^ a break of what ?
.... that kit kat bar.
Geovone is offline   Reply With Quote
who goes by oil life? Oil percent, First Oil Change Oil Monititor Threads Merged RockALittle250 Mechanical Problems & Technical Chat 294 02-05-2010 05:31 AM
US Oil Dip Stick Vs. JDM K20a Dip Stick?? JDMFA54DR Civic Coupe And Sedan 9 09-22-2009 07:55 AM
Oil Life Meter still reading low? sicivic22 Mechanical Problems & Technical Chat 9 07-01-2009 07:32 PM
oil dipstick (weird reading) yourwhiteshadow Civic SI 19 01-08-2008 11:24 PM
Do you go by miles or oil life reading for oil change? nsl Do It Yourself Articles 4 08-03-2007 09:14 PM
