Old 11-12-2006, 02:39 AM   #1 (permalink)
edrhee83's Avatar
Ed Rhee
I just installed Skunk2 exhaust and got questions~
I installed Skunk2 exhaust and whenever I start up the car cold, it makes click noise when I start up from the below if as the exhaust is moving. It only happens during startup. Is this normal?
edrhee83 is offline   Reply With Quote
Old 11-12-2006, 05:17 PM   #2 (permalink)
Type X's Avatar
recheck bolts & hang'r's lol
Type X is offline   Reply With Quote
Old 11-12-2006, 06:24 PM   #3 (permalink)
jda07Si's Avatar
does seem to have rubbing/bumping issues, especially with the heat shield
all my connections and hangers are tight as can be and i have occasionally had rattling due to what i think is the exhaust knocking off the heat shield
put it up on a lift, moved it away from the shield, made sure everything was secure....sure enough a day later i had the rattling again.....so i don't know may have to buy some type of aftermarket hanger or latch to secure it, because moving it around isn't working.
jda07Si is offline   Reply With Quote
Old 11-12-2006, 07:17 PM   #4 (permalink)
adamhoud's Avatar
Adam
I've had mine on almost 2 weeks and no rattling or bumping, used stock bolts on cats also.
adamhoud is offline   Reply With Quote
Old 11-13-2006, 10:24 AM   #5 (permalink)
edrhee83's Avatar
Ed Rhee
I didnt use the stock bolts. I took em out and used the ones that came with the exhaust. And for me, it only rattles during startup. Weird..
Old 02-13-2007, 02:15 AM   #6 (permalink)
mine rattles.
Reliant K20Z3 is offline   Reply With Quote
Old 02-22-2007, 07:30 PM   #7 (permalink)
Thinner Dirties
HanCivicSI's Avatar
G
The hangars seem long on the muffler and may tap a thin piece of metal under the bumper. You can cut some of the metal away or try to bend it. I used a rubber stopper and slid over the ends of the hangars on the muffler. No rub or rattle now!
HanCivicSI is offline   Reply With Quote
Old 02-23-2007, 03:43 AM   #8 (permalink)
reaper702's Avatar
no rattles here or clicking noise. double check the hangers on the muffler tip.
reaper702 is offline   Reply With Quote
