Steering wheel feels very twitchy - 8th Generation Honda Civic Forum
Old 02-11-2010, 07:10 AM   #1 (permalink)
Lek
Lek's Avatar
Lek just put it into 1st gear on 8thcivic
Cool Steering wheel feels very twitchy
I just took delivery of a New 2010 Civic sedan for my wife and straight away I noticed that the steering wheel feels very twitchy/sensitive/jumpy. It just doesn't feel firm like my other cars.
I had an good alignment done and the car now runs in straight line better, but the steering still feels twitchy/sensitive/jumpy.
Is this normal for the 2006/10 Civic or is there a fix at Honda?
Lek is offline
Old 02-11-2010, 07:21 AM   #2 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
FijiBlueFG2HT just put it into 1st gear on 8thcivic
Twitchy?
Check your tire pressure.
FijiBlueFG2HT is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 07:46 AM   #3 (permalink)
Lek
Lek's Avatar
Did that with the wheel alignment.
Lek is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 11:11 AM   #4 (permalink)
Mitch [Ryan #3]
Maybe you're just not used to the Civic?
Old 02-11-2010, 07:33 PM   #5 (permalink)
Lek
Lek's Avatar
It's a strange feeling, for example, I am driving in a perfectly straight line and the steering wheel is 100% straight, then the car runs over an ever so slight imperfection on the road and the steering wheel jumps slightly to the left or right very quickly and I must correct it. Just a bit too sensitive.
Is this a typical Civic FD?
Old 02-11-2010, 09:03 PM   #6 (permalink)
Lek
Lek's Avatar
Maybe the technical word for this problem is BUMP STEER. Is there a simple correction?
Old 02-11-2010, 10:12 PM   #7 (permalink)
actionjeans's Avatar
Vaughn
actionjeans just put it into 1st gear on 8thcivic
Typical Si with decent tires, can't say for the FD, but probably. I would use the word accurate, over twitchy.
actionjeans is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 10:28 PM   #8 (permalink)
iphydeauxi just put it into 1st gear on 8thcivic
What trim level?
iphydeauxi is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 10:35 PM   #9 (permalink)
JDMFGSI's Avatar
Tommy GuNZ
JDMFGSI just put it into 1st gear on 8thcivic
mine does the same thing on the freeway...i think the steering is too sensitive
JDMFGSI is offline   Reply With Quote Quick reply to this message
Old 02-12-2010, 12:26 AM   #10 (permalink)
Eric.'s Avatar
Eric
Eric. just put it into 1st gear on 8thcivic
You've never driven a Miata, have you? Haha. Sounds like you'd steer yourself off the highway first thing if you did.
Eric. is offline   Reply With Quote Quick reply to this message
Old 02-12-2010, 07:07 AM   #11 (permalink)
Lek
Lek's Avatar
Today, I took the car to Honda and explained the problem and he smiled.
Anyway, the technician and I drove to the rear of the Honda garage where they had a special area of road with raised cobbles. Driving over them the steering wheel was twiching like crazy. He then tested the car on various roads for about 5km and said nothing.
Technicians conclusion, normal, but to me it just seems like the steering rack needs tightning a bit. Is it possible?
Old 02-12-2010, 07:33 AM   #12 (permalink)
B MAN's Avatar
Brian
B MAN just put it into 1st gear on 8thcivic
if they say its normal, id take their word for it
B MAN is offline   Reply With Quote Quick reply to this message
Old 02-12-2010, 07:43 AM   #13 (permalink)
Lek
Lek's Avatar
Guess so!!!!!
Old 02-12-2010, 05:46 PM   #14 (permalink)
BlairSpeed's Avatar
BlairSpeed just put it into 1st gear on 8thcivic
Well, the Si's have EPS which feels very different then hydrolic racks. When I first drove my FA5, that was the first thing I noticed, very light steering and bump steer. But i think you have a non-Si sedan which all have standard hydrolic racks.
BlairSpeed is offline   Reply With Quote Quick reply to this message
Old 02-14-2010, 10:01 AM   #15 (permalink)
Lek
Lek's Avatar
OK, I took it to another dealer today and they did an adjustment in the steering rack. It feels much better now.
Old 03-25-2010, 09:42 PM   #16 (permalink)
Lek
Lek's Avatar
This problem is called bump steer and I have been told it's a typical Civic problem.
Old 07-22-2010, 11:24 PM   #17 (permalink)
Lek
Lek's Avatar
Here's the fix. It may take 2 or 3 adjustments to get it right.
http://media.honda.co.uk/car/owner/m...SH200/11-4.pdf
Old 07-23-2010, 07:11 PM   #18 (permalink)
SWRT likes to double clutchSWRT likes to double clutchSWRT likes to double clutch
Bump steer is a geometry based characteristic, what your dealer adjusted was steering friction... completely different.
If it feels better to you, then perhaps friction was too low... but the steering rack supplier checks friction 100%... so its very unlikely. What you were probably noticing was the 7deg caster the 8th gen Civic has. It makes the car have a very strong on centre feel with steep gain on either side. Its a characteristic of the design and its normal.
If you compare a 2006 Civic with an 09 or 10 you may notice the steering friction is higher. It was changed because of too many customers complaining about the car pulling to the side.
I would not recommend people making adjustments to their rack friction, its very easy to really screw up your returnability (make a turn and the wheel won't got all the way back to centre). Dealer's 'can' do it, but most of them will screw it up too.
That adjustment is there for high mileage racks where there is actually a rack rattle noise.
-SWRT
SWRT is offline   Reply With Quote Quick reply to this message
Old 07-23-2010, 11:03 PM   #19 (permalink)
kennersi's Avatar
josh
kennersi just put it into 1st gear on 8thcivic
check tire pressure.. mine feels very firmm.
kennersi is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 03:04 AM   #20 (permalink)
Kakashi's Avatar
Avan
Kakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with glee
I love the sensitivity.
Kakashi is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
My civic steering feels heavy !! HELP ! xheartcore_boyx Mechanical Problems & Technical Chat 15 04-06-2011 02:28 PM
Steering wheel feels lose on freeway. 06CivEXJon Mechanical Problems & Technical Chat 19 01-26-2010 03:21 PM
Steering Wheel Help!! WiseGuyLX Inside and Out 13 04-04-2008 03:36 PM
Twitchy ABS - 07 Si Sedan kronusthebonus Suspension and Brakes 8 07-07-2007 08:56 PM
