#2 (permalink) | |
Now to your question: Stop or brake lights are the brighter filament bulb that lights when you press the brake pedal. Tail light is typically used to describe the entire lamp assembly, but can also be used to refer to the running lights which are the dimmer bulbs that are illuminated whenever the headlight switch is turned on. Turn signal (depending on the configuration of the assembly) may use the same bright filament as the brake light, or may use a separate bulb. If I'm not mistaken, our 8th Gen Civics use the same bulb (and filament) for both the brake light and turn signals. Hope that helps. |
Ummm, nope, with respects, that's wrong. The part about the brake and turn signals being the same on 8th Gen Civics that is.
I just wired my car for a trailer and the brake lights and turn signals are seperate circuits. The tail lights have two bulbs, one on the trunk lid and the other on the body itself, just outboard of the trunk lid on each side. The brake lights work off a dual element bulb where one filement is brighter than the other (as you described) and they're behind the body mounted lenses. The turn signals are also body mounted and they operate just below the tail/brake lights, outboard of the backup lights. FWIW! :) Drive Safe. Steve R. |
#4 (permalink) | |
#7 (permalink) | |
Upon further investigation (I got my wife to work the lights on my car) The running/stop light is a dual-filament bulb. The turn signal is a separate orange bulb that shares the clear center part of the lens with the backup light.I learned something new here. I guess I've never followed an 8th gen coupe... Edited to update new info - I got off my lazy tushie and went to look. Last edited by CoryB; 11-03-2006 at 09:43 PM. |
#8 (permalink) | |
Sorry if I caused any confusion. :) Drive Safe, Steve R. |
#9 (permalink) | |
I bought a light utility trailer and am building a box to hold my stuff. I don't think I'll have any problems keeping the total weight under the car's rated capacity. Drive Safe, Steve R. |
#11 (permalink) | |
| Dumb Laws | C2i0v0i1c | Water Cooler | 61 | 11-20-2008 01:07 PM |
| OEM Fogs, I want the fogs to turn on with parking lights | Hotwheels | Do It Yourself Articles | 33 | 11-10-2008 02:29 PM |
| Smokin' Sexy TAIL Lights + All BLACK GRILL. [ DIY Guide] (PiX) | Tikolx333 | Lighting | 44 | 07-31-2008 12:05 AM |
