Location: NJ (no, not Ct, those are my initials and where I grew up)
Fred
30K with or without tran fluid exchange?
So I need my 30K checkup on my 2007 Civic next week. Last time the dealership gave me their sheet with the little description of their 30K service options. The only big cost difference is whether to do "automatic transmission service" or "automatic transmission service with transmission fluid exchange", which adds $115.
I assume this means a tran fluid drain & refill? Not a flush? Is this something that's worth doing at 30K? Or is it a ripoff? What would you do? |
![]() Join Date: Nov 2007
Bruce
Buy alll the stuff and do a Drain and Fill, I do a drain and fill on mine every other oil change. its worth it to keep the tranny in good shape
![]() Bert: I think I need some Yaz! Rabbit: I knew you had a Fwakin Vagaina! |
Fred
I knew that'd be the first responses I'd get... I meant to mention, I'm not a do-it-yourself guy, primarily because I have no one to show me how. I'm not doing to risk messing up my car when I have little idea what I'm doing. It ain't worth it.
Even if I was, it's like been freezing here and even if I knew how, I don't think I'd have much interest in doing it in the freezing cold - I live in an apartment so I have no garage to do it in. So my real question is, is it a good mechanical idea to do a fluid exchange at this stage? Or is it a waste? What would you do (if do-it-yourself wasn't an option)? |
I was told at my local dealership that at 30 thousand miles you need to change out your brake fluid. You don't need to change out the transmission fluid until 50 thousand miles. Yes I also agree, I would rather have someone do it for me as well since I am not mechanically inclined. But for what the service entails 300 dollars is an outrageous price.
Fred
Okay, so it seems like the general consensus is that a drain/refill in a good thing to do at 30K, but questioning the price.
The total price is definitely higher than I'd like, so I think I'll ask them if there are any discounts currently available or otherwise shop it around with other nearby dealers. But unless there's someone in northern/central NJ who wants to give me a hands on tutorial , I do need a pro to do it, but I'll just get the best deal I can.Update: a brief web search seems to show another nearby dealer that has the 30K package with basically the same items (I believe - I'll need to check vs. the sheet I have at home), except they do it all for less than the lower package (the one with no trans drain & refill) at the other dealer. By the way, this other dealer I actually started going to because it was cheaper than the one I first started at, which was crazy expensive. Last edited by fredct; 12-14-2009 at 09:22 AM. |
#11 (permalink) |
Brian
There is a step by step guide on this forum
But if you still don't think you can manage go to an independant mechanic with good reviews and have it done, should be 70-80 bucks |
#12 (permalink) | |
Wegue Wegue
![]() Join Date: Jan 2007
Adrian
![]() I'm at 110,000 km and my tranny fluid is still 'okay' I'll do it my next oil change (in about 9,000 km) The service minder should show you a B3 service which is a tranny fluid exchange service. (it's funny that my Honda dealership has no idea when that service is suppose to come up) And.. $115 extra for what? it's only $65cdn here for tranny fluid drain and flush.. mind you it was the same dealership, they may be smoking crack. |
| 08 Civic LX tran issues | RageOn | Civic Coupe And Sedan | 10 | 10-29-2008 09:07 PM |
| Manual Tran - CIVIC Si in Lawrenceville | goixiz | Georgia | 3 | 09-10-2008 07:05 PM |
| Quick Manual Tran. Question | jaxson | Civic SI | 16 | 09-09-2008 05:12 PM |
| swapping auto tran with manual | uhsenLX | Bolt-Ons And All-Motor | 7 | 02-20-2008 12:57 AM |
| Auto Tran DBW -Fixed!!!! | bmw325 | Mechanical Problems & Technical Chat | 15 | 10-15-2006 08:11 PM |
