Feels like Sticky Clutch (COLD WEATHER)
I currently reside in Edmonton Alberta, and it gets down to about -35 degrees CELCIUS around here.
2009 si , 6000kms, pretty much brand new Recently I've been noticing the clutch is harder to push down and takes a noticable while to come back up on its own. In other words, theres a conciderable amount of resistance when working the clutch. Im wondering if this is a problem with the clutch or just the fluids becoming like jello due to this weather? I noticed it about a week ago, which is when the extremely cold weather came around. Anyone help me out? Thanks |
I would think that any issues due to temperature would become less noticable or go away all together after the car has warmed up completely. If ur clutch is still like this even after a decent drive I would look for somethng else to be the issue. I could be wrng on that since its so cold....
Jeremy
Fluid gets less viscous as it gets colder. My clutch does the same thing here in Maine and I am not quite as cold as you. Assuming the feeling goes away as the car warms up, it sounds pretty normal.
#5 (permalink) | |
Barry
nah it's totally normal. i live in calgary and once it gets to the magical -20 range the clutch stiffens up and gets better once it's warmed up/tranny fluid gets warmed up. usually takes about 20-30mins of driving for mine to feel a little looser. |
thanks all,
hmm relating to that one response about after the car warms up: The thing is start my car for 10 mins then it feels fine for about 2 minutes on the road. Then the same feeling of resistance. I park and let it idle outside for about 5 mins, and its all better then repeats when I drive again. Im thinking because of the cold air? |
#11 (permalink) |
Dave
Have any of you guys noticed you clutch skip or chatter when you take off when its really cold??? Seemed to only start doing it since the cold air has come in..
It seems to go away after a lil while, but my clutch seems to still be catching high on the pedal?? Car has 50K miles on it. I cant imagine I would already need a new clutch? Any input?? |
#12 (permalink) |
Mitch [Ryan #3]
You get used to it. I actually feel colder when its 55 degrees out on a summer night than when its 25 degrees out on a winter night. Its weird, your body adjusts to it.
#13 (permalink) | |
Mitch [Ryan #3]
#15 (permalink) | |
In regards to it getting stiffer after a few minutes of driving, its due to the wind chill we get. The cold air gets into your engine compartment and underside of the car while moving, which starts to freeze everything again, thus you feel the stiffness return, especially when you're driving on the henday or highways |
#17 (permalink) |
That happens on my car whenever the overnight temps get really low. It does make for some effortlessly smooth gear changes in the morning though as the clutch pedal takes a few seconds to come back up on it's own.
| LOL ok E-brake Cold weather | haho207 | Mechanical Problems & Technical Chat | 16 | 10-24-2009 08:41 PM |
| My clutch felt.. sticky? | Haz Mat | Mechanical Problems & Technical Chat | 0 | 05-26-2009 06:30 PM |
| im loving cold weather! | civicfreak25 | Autocross & Sanctioned Drag Racing | 2 | 10-09-2008 09:20 AM |
| R18 feels faster in hot weather rather than cold weather | dattebayo | Dealership Experience | 10 | 05-13-2008 03:23 PM |
| Si in cold weather | TJ213 | Civic SI | 20 | 05-07-2008 09:24 PM |
