VSA and /!\ lights come on out of nowhere. - 8th Generation Honda Civic Forum
Old 12-12-2009, 12:46 PM   #1 (permalink)
belizetj's Avatar
Thomas
Im driving down the road in my 2008 Mugen Si, and out of nowhere my VSA and /!\ light come on. I press the VSA OFF button. Nothing happens. So i pull off the road. I shut the car off. Then restart it. Both lights go off. I continue driving.
This has happend to me 5 times in the past 3 months. My car is stock except S2 exhaust and k&n filter. Does anyone know what the problem could be?
UPDATED: It was a fault in the brake switch causing the VSA and /!\ lights to come on. The fix was under warranty, took about 10mins.
belizetj is offline
Old 12-12-2009, 01:00 PM   #2 (permalink)
Sam
Search, damnit.
VSA and /!\ light stays on?
AntiGravityHero is offline   Reply With Quote
Old 12-12-2009, 01:11 PM   #3 (permalink)
belizetj's Avatar
Thomas
Originally Posted by AntiGravityHero View Post
Damnit, I did. They didn't answer the question. If it was the fuse it would stay on. DTNguyen107's came on due to braking. Mine just comes on.
belizetj is offline   Reply With Quote
Old 12-12-2009, 01:59 PM   #4 (permalink)
nayilsi's Avatar
wiring fault?
Old 12-12-2009, 05:15 PM   #5 (permalink)
belizetj's Avatar
Thomas
Originally Posted by nayilsi View Post
wiring fault?
Idk. Vsa (on or off) works perfectly normal until the lights come on.
Old 12-13-2009, 02:10 PM   #6 (permalink)
actionjeans's Avatar
Vaughn
You would likely be able to pull a code from that when both lights are on. The VSA failing a self check, which is why the lights are showing up; either hook up a code reader to it and see what it says (if you have one) or take it to the dealer or a Honda shop and see if they can pull the code, and that should give you a direction to go.
actionjeans is offline   Reply With Quote
Old 12-13-2009, 02:13 PM   #7 (permalink)
FGRedline's Avatar
Haha at people like this. They act like its the biggest inconvenience that their eyes had to come across a thread that they had already seen. Polluting their web space and wasting his precious time on the 8th.
Who gives a . Bump for OP to get help.
FGRedline is offline   Reply With Quote
Old 12-13-2009, 02:17 PM   #8 (permalink)
Haz Mat's Avatar
Chris
What was the other light on the right side of the gauges? TPMS? It was too hard to see it.
Haz Mat is offline   Reply With Quote
Old 12-13-2009, 02:55 PM   #9 (permalink)
portabuddy's Avatar
Thats Mr.Bart to you!
I had the same thing. my VSA and the ! came on. only while it was raining. it was a fault with the yaw-rate-sensor... the thing that determins in what direction and at what angle the car is travaling in... like if you start spinning it knows what way forward is and brakes accordenly to straighten you out.
I dropped my car off for a few days and they fixed her up.
Life dosn't have a reset button, if it did you may as well turn the game off. -portabuddy
Originally Posted by George Carlin
"Its called the American dream, because you have to be asleep in order to believe in it."
portabuddy is offline   Reply With Quote
Old 12-13-2009, 03:11 PM   #10 (permalink)
Jaralaccs's Avatar
the ! = VSA activation indicator
If its blinking it means VSA function is activating.
it comes on and stays on when the VSA function is lost, or you if turned it off.
anyway, like someone already said, there's an intermittent fault, there is going to be codes stored, just like a check engine light. take it to your dealer
Jaralaccs is offline   Reply With Quote
Old 12-13-2009, 07:07 PM   #11 (permalink)
portabuddy's Avatar
there is no way to fix it yourself and resetting the battery will do nothing also. Nothing but piss you off that is.
Its a fault with the wiring or a sensor. In my case it happened right after i dropped it and modded the suspension. i might have inadvertently bumped the thing? its possible. but it might have also been like that from factory.
Old 12-13-2009, 07:51 PM   #12 (permalink)
HFPK20's Avatar
mine came on when my rear wheels bearing went out.. and somehow triggured the sensor
HFPK20 is offline   Reply With Quote
Old 12-13-2009, 08:20 PM   #13 (permalink)
belizetj's Avatar
Thomas
Thanks. Imma take it to the dealership tomarrow. Its still under warranty so i think they should fix it.
Old 12-13-2009, 08:22 PM   #14 (permalink)
belizetj's Avatar
Thomas
Originally Posted by haz mat View Post
what was the other light on the right side of the gauges? Tpms? It was too hard to see it.
brake
Old 12-13-2009, 08:23 PM   #15 (permalink)
belizetj's Avatar
Thomas
Was it under warranty?
Old 12-13-2009, 08:25 PM   #16 (permalink)
belizetj's Avatar
Thomas
Did it stay on or did it come on occasionally like mine?
Old 12-13-2009, 08:28 PM   #17 (permalink)
belizetj's Avatar
Thomas
Thanks. I will take it there tomarrow. Its still under warranty. Do you think they will charge me?
Old 12-13-2009, 08:31 PM   #18 (permalink)
belizetj's Avatar
Thomas
Old 12-13-2009, 10:34 PM   #19 (permalink)
Vaughn
No, if it's still under warranty (36k 3yr warranty, as I don't think this would be covered under the longer drivetrain one), it should be zero charge.
Old 12-13-2009, 10:36 PM   #20 (permalink)
ggfa5's Avatar
Robert is HELLA SF
Check fuse 12 under the hood.
ggfa5 is offline   Reply With Quote
CEL/VSA/! lights on SHG_Mike Mechanical Problems & Technical Chat 13 11-02-2011 12:03 AM
VSA ABS lights after install simplejim336 Suspension and Brakes 5 11-03-2009 11:45 PM
ABS VSA AND BREAK LIGHTS come on Wattah4u Mechanical Problems & Technical Chat 12 09-19-2009 03:02 PM
Intermittent ABS&VSA Lights.. HELP omgzlis Mechanical Problems & Technical Chat 1 09-08-2009 03:07 AM
VSA & ABS lights flash wagoneer Mechanical Problems & Technical Chat 2 12-13-2008 01:53 PM
