How hard to replace passenger side motor mount ? - 8th Generation Honda Civic Forum
Old 12-11-2009, 09:51 PM   #1 (permalink)
Humberto Benavides
Question How hard to replace passenger side motor mount ?
The passenger side motor mount on my 2006 Honda Civic Coupe LX is now shot ! how hard is it to replace it with a new one ? I just ordered the new OEM part from the dealer but I don't want to be ripped by the dealer with their exagerated costs, so I'm planning to replace it myself, does any body knows if it's hard and how hard ? Thanks in advance !
humbertob is offline
Old 12-11-2009, 09:56 PM   #2 (permalink)
Willyo224's Avatar
Boss- Ross
IFA
But You i think that should be tough!
Willyo224 is offline   Reply With Quote
Old 12-11-2009, 10:02 PM   #3 (permalink)
Zeuceone's Avatar
Do you have a picture of it on the car?
Old 12-11-2009, 10:20 PM   #4 (permalink)
RIP Mom and Dad
NickC89's Avatar
Nick
NickC89 is offline   Reply With Quote
Old 12-11-2009, 10:23 PM   #5 (permalink)
Willyo224's Avatar
Boss- Ross
^ good Info! when i put my Jet rocket in my car i might need stronger mounts!
Old 12-11-2009, 10:31 PM   #6 (permalink)
Humberto Benavides
Cool Thanks
Thanks NickC89, that's the graphic that I saw at the dealership's web site when ordering my new motor mount, but I need to know if any one here have changed a motor mount before and how tough would be !
humbertob is offline   Reply With Quote
Old 12-11-2009, 10:33 PM   #7 (permalink)
Willyo224's Avatar
Boss- Ross
alright all seriousness.... If you didn't know what to do... or aren't fond of Renchin... I wouldn't attemp this... a engine is heavy azz hell and you would want to bend or damage other mounts... I would look for a local shope that could help you out if you don't wanna pay the dealership.... Otherwise all you need is a series of torque renches... and air tools... who know a strong Jack... jackstands, a lift, maybe even a Engine hoist...
Old 12-11-2009, 10:47 PM   #8 (permalink)
DavisLasVegas's Avatar
Dave
just put a floor jack with a cut piece of 2x4 on it under the oil pan to support the engine then removal should be a snap.
DavisLasVegas is offline   Reply With Quote
Old 12-11-2009, 10:51 PM   #9 (permalink)
asndragonboii's Avatar
Even though you havnt done a motor mount before, are you mechanically inclined and have proper tools? If you are, get a service manual. It will help you alot.
Honda Civic Accessories - Maintenance Items
Scroll down about 1/4 way
Old 12-11-2009, 10:52 PM   #10 (permalink)
Zeuceone's Avatar
I might make a diy soon on removing the dogbones.
Old 12-11-2009, 10:52 PM   #11 (permalink)
Willyo224's Avatar
Boss- Ross
Old 12-11-2009, 10:56 PM   #12 (permalink)
1. Support the engine with a jack and a wood block under the oil pan.
2. Remove the bolt (A) securing the A/C line, then remove the upper torque rod (B).
3. Remove the ground cable (A), then remove the side engine mount bracket (B).
4. Install the side engine mount bracket, then loosely tighten the new bolt and nut (C), and loosely tighten the bolt (D).
5. Install the ground cable.
6. Remove the air cleaner housing assembly.
7. Loosen the transmission mounting bolt and nuts (A).
8. Raise the hoist to full height.
9. Loosen the lower torque rod mounting bolt (A).
10. Lower the vehicle on the hoist.
11. Tighten the side engine mount mounting bolts and nut.
12. Tighten the transmission mounting bolt and nuts.
13. Raise the hoist to full height.
14. Tighten the lower torque rod mounting bolt.
15. Lower the vehicle on the hoist.
16. Install the air cleaner housing assembly.
17. Install the upper torque rod (A), then tighten the new upper torque rod mounting bolts in the numbered sequence shown.
18. Install the bolt (B) securing the A/C line.
Old 12-11-2009, 11:00 PM   #13 (permalink)
Willyo224's Avatar
Boss- Ross
^ good ish!
Old 12-17-2009, 02:46 PM   #14 (permalink)
Humberto Benavides
Update: Well, my personal mechanic just replaced the motor mount for me and the problem is now completely solved ! All the weird sounds have gone. Just paid $96.00 including shipping for the oem motor mount from hondaautomotiveparts.com and like $30 dlls for the labor. The mechanic just took like 2 hours to complete the job, and now my lovely car feels new again ! Thanks to all for all your advice ! Have a Great Holiday and God Bless this Forum and all it's members !
Old 12-17-2009, 03:15 PM   #15 (permalink)
tpattgeek's Avatar
So what are the symptoms of a shot motor mount? vibrating? weird noises?
tpattgeek is offline   Reply With Quote
Old 12-17-2009, 03:40 PM   #16 (permalink)
Stephen
well, i know another person with an 06 lx and that very same motor mount went on his with 7x,000 miles on it.
I'm starting to wonder if honda just **** the bed on making all these cars...
w00t692 is online now   Reply With Quote
Old 12-17-2009, 03:43 PM   #17 (permalink)
andrew
ive done this myself...its not to bad if u have a breaker bar
the rubber on top can also be torn/cracking
oneeightseven is offline   Reply With Quote
Old 12-17-2009, 03:44 PM   #18 (permalink)
andrew
very true passenger mount lasted like 25,000 now i have 120 and my driver side mount is shot and i dive like an old lady its not like i gas the hell out of my ****
Old 12-17-2009, 05:14 PM   #19 (permalink)
Humberto Benavides
Wink Motor Mount shot symptomps
Symptoms on mine were: Noises coming from the motor mount area when hitting potholes, a little vibration when turning on the motor on the car, and little vibrations when idling, all of that is now gone !
Bad Motor mount - rattle on right front side leonsphinx Mechanical Problems & Technical Chat 19 09-10-2011 10:15 AM
When is it time to replace motor mounts? Monsterbishi Engine Swaps, Mounts, Pulleys 8 11-06-2009 02:31 PM
Motor Mount question skunk2civic Mechanical Problems & Technical Chat 3 08-23-2009 10:53 PM
Is it just Me? Driver side headlight aimed higher than passenger side Tongman Lighting, H.I.D.'s, & Neon 5 08-09-2009 10:17 PM
Car tilting or leaning towards driver side more then passenger side.. imported_06civic Mechanical Problems & Technical Chat 8 04-05-2006 11:51 PM
