Rear Wheel Bearing
as im driving my 08 civic si sedan down the highway there is an odd vibrating sound coming from my right rear tire. im not sure if its a wheel bearing or what but as i go faster it gets quicker. i figure its a wheel bearing and i noticed there is a recall on them but mine doesnt fit the list.
True, sorry, I mis-interpreted your post and didn't realize you were specifying load.
To your point, HARD turning should change the sound. Nonetheless, it's tough to load up the rear anywhere near the degree of the front due to how little weight rests in the rear of the car. And obviously you can't just turn the wheel and listen for a change. Staab - If the sound doesn't change when you switch gears and it increases with speed, it's most likely either a wheel bearing or tire noise. Try rotating your tires. If the noise doesn't move, then it's most likely a wheel bearing. Covered under warranty. Tire noise not covered under warranty
The mugen still rolls plenty. It's not that much different than the stock SI
![]() Roll is not a bad thing and, in some cases, will benefit actual grip versus perceived grip. For example, in my 2008 legacy GT I put on a set of cobb sway bars. Pretty much eliminated all but a bit of roll, but I lost ultimate traction because of the way lateral forces are transfered onto the rubber. Anyway, rotate tires and then decide if a dealer visit is needed. |
#10 (permalink) |
Ray
Sounds like you had the same problem as me...read through my thread LOTS of info on this...
Loud Humm -- New Wheel Bearings?? |
| Rear Wheel Bearing Failure at 65K Miles | Doolie77 | Suspension and Brakes | 43 | 10-26-2011 02:44 PM |
| Safety Recall: Rear Wheel Bearing | type-si | BC, Yukon, & NWT | 23 | 07-30-2009 08:30 PM |
| Wheel Bearing or Not ? | petrolhead | Mechanical Problems & Technical Chat | 3 | 04-17-2009 11:04 AM |
| wheel bearing problem | zspeedzkwy | Mechanical Problems & Technical Chat | 2 | 01-25-2008 10:49 AM |
| Rear wheel bearing TOAST! | janaka | Mechanical Problems & Technical Chat | 12 | 03-28-2007 03:25 PM |
