HELP! Adjusting Automatic Shifter Cable HELP! - 8th Generation Honda Civic Forum
Old 12-10-2009, 04:53 PM   #1 (permalink)
I hit my girls automatic shifter lever kinda hard putting a box in the car and now I can't get the keys out of the ignition.
Can someone explain how to adjust the shifter cable or maybe post up a service .PDF or explain how to do it. She's VERY pissed off!!! ha ha
EternalBlueEX is offline
Old 12-10-2009, 10:09 PM   #2 (permalink)
DavisLasVegas's Avatar
Dave
take the center console back apart and see what you bent.
DavisLasVegas is offline   Reply With Quote
Old 12-14-2009, 12:30 PM   #3 (permalink)
Are u a tech?...
bump... didn't hit it THAT hard. Can someone post a .PDF from the service manual or explain how to adjust the shifter cable.
EternalBlueEX is offline   Reply With Quote
Old 12-14-2009, 04:15 PM   #4 (permalink)
Dave
actually i am. and no matter what you have to take the center console back apart to make the adjustment. sorry i can't copy the service manual and put it in pdf form, but i can tell you it's gonna take a bit of work to adjust it. i'd recommend taking it to someone unless someone on here is willing to copy the service manual for you.
Old 12-14-2009, 04:25 PM   #5 (permalink)
Wegue Wegue
Cr8tive_leo's Avatar
Adrian
Originally Posted by EternalBlueEX View Post
I hit my girls automatic shifter lever kinda hard putting a box in the car and now I can't get the keys out of the ignition....
How does hitting the shifter get the key stuck? I've hit my shifter with a hammer , wheels, rims, boxes, slammed it forward, yanked it back, and never have I had the key stuck in the ignition.
Try removing the ring around shifter to give it more play forward and back. you also may have jammed the the trigger so it doesn't engage the switch. easiest way is to remove the knob and re install it.
There are a lot of DIY's on shifter swaps for the AT.
DIY - Automatic Shift Knob Replacement
that's just one of them.
Cr8tive_leo is online now   Reply With Quote
Old 12-14-2009, 07:33 PM   #6 (permalink)
av911's Avatar
IIRC, the shifter has to be in PARK in order for you to take the key out. It happened to me a couple of times when I turned off my engine while in DRIVE and tried to take the key out. Maybe, that's what happened???
Old 12-15-2009, 04:59 AM   #7 (permalink)
07AlBLKeX305's Avatar
8thFLcrew212/I<3DrivingSlow212
The title says Automatic shifter cable.
07AlBLKeX305 is offline   Reply With Quote
Old 12-17-2009, 03:39 PM   #8 (permalink)
I'll try some of those idea's, thanks everybody, anybody else got anything?...
Old 12-21-2009, 02:34 PM   #9 (permalink)
bump...
Old 12-21-2009, 05:01 PM   #10 (permalink)
Dave
still got the key stuck? if you're around denver co i can help you.
Old 12-21-2009, 05:26 PM   #11 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
FijiBlueFG2HT is offline   Reply With Quote
Old 12-22-2009, 12:24 PM   #12 (permalink)
djpaw's Avatar
haha.....you do believe in 'reading between the lines' don't u.
djpaw is offline   Reply With Quote
Old 12-30-2009, 01:28 PM   #13 (permalink)
Turns out the cars a extended warranty so were making an appointment. Hope they don't rty to charge me anything. Thanks for all the help guys? Anyone else have a easy .PDF service manual fix for this?
Adjusting shifter knob height? david3558 Inside and Out 15 03-04-2008 07:44 PM
Review: TWM Short Shifter & Cable/Shifter Bushings unplugged Bolt-Ons And All-Motor 11 04-09-2007 12:43 AM
HELP WITH MY AUTOMATIC SHIFTER!! lightlypurified Mechanical Problems & Technical Chat 6 03-16-2007 02:07 PM
Automatic trans shifter question asndragonboii Civic Coupe And Sedan 40 08-22-2006 10:02 PM
