Windshield washer fluid won't spray...Help! - 8th Generation Honda Civic Forum
Old 12-10-2009, 10:43 AM   #1 (permalink)
tcd2004's Avatar
Well it's a nice 15 degree morning here in Michigan and with all the wet snow getting thrown on my windshield I need to use my washer fluid quite a bit. When I left my house I sprayed and it came out just fine. About 15 minutes into my drive I pulled the washer fluid lever and nothing came out, not even a little spray. I can hear the motors going, but absolutely nothing is coming out. Now I just put nearly an entire gallon of fluid into the tank yesterday so I know it's not out, is it possible that the system is frozen? I thought the fluid stayed good until -20 degrees, but I don't know what else could have happened in my short drive. Has anyone else experienced this?
tcd2004 is offline
Old 12-10-2009, 10:49 AM   #2 (permalink)
Six eyes
J-Ro's Avatar
Jason
Maybe a tube came loose somewhere? You could try getting someone to hit the sprayers and check if you can see fluid dripping underneath the car.
I'm so JDM, my girlfriend is Japanese.
私はあまりにもJDMなので、私の彼女は日本人です。
Old 12-10-2009, 10:49 AM   #3 (permalink)
fre$h si's Avatar
Bobby
Could be frozen, but there's a good chance the line to the sprayers got disconnected cuz that happened to me. The lines run inside the cowling incase u wanna check
fre$h si is online now   Reply With Quote
Old 12-10-2009, 11:19 AM   #4 (permalink)
tcd2004's Avatar
How hard is it to take the cowl off? Is there a DIY on it?
tcd2004 is offline   Reply With Quote
Old 12-10-2009, 03:04 PM   #5 (permalink)
Six eyes
J-Ro's Avatar
Jason
There are 3 small clips on the front edge (gloss finish, flat heads)... take those out then pull up!
Old 12-10-2009, 08:15 PM   #6 (permalink)
tcd2004's Avatar
Well There are no tubes disconnected underneath the cowling. I just took off a small cover on the passenger side and saw the tube that connected the two sprayers. I pinched it a few times and washer fluid came out of the sprayers so I know that is connected OK. The reservoir is completely full as well. So basically I know that the motor is going, the tubes are connected to the sprayers, and the fluid is full... could it be that temperatures between 10 and 15 degrees could freeze the line that feeds the pump? I tried finding access to the main line but no matter which way I looked I couldn't find a way. Any input would be appreciated.
Old 12-10-2009, 08:18 PM   #7 (permalink)
adamway's Avatar
Adam
Pour some anti freeze in your windshield wash bottle. if it is indeed something froze up, then that should help.
adamway is offline   Reply With Quote
Old 12-10-2009, 08:19 PM   #8 (permalink)
tcd2004's Avatar
Is that safe to do?
Old 12-10-2009, 09:08 PM   #9 (permalink)
drivelikeyoustoleit's Avatar
Adam
check the washer sprayers themselves on the hood this happened to me last year the One time VA got a decent snow.... went inside got hot water then poured hot water on the sprayers worked like new again.... sometimes the washer fluid will freeze up right at the end. Only knew of this because i learned how to drive in snow up in northern Ohio lol.
drivelikeyoustoleit is offline   Reply With Quote
Old 12-10-2009, 09:13 PM   #10 (permalink)
The Power of Dreams's Avatar
Perhaps there is a clog somewhere in the main line.
The Power of Dreams is offline   Reply With Quote
Old 12-10-2009, 09:14 PM   #11 (permalink)
tcd2004's Avatar
How would I get to that?
Old 12-24-2009, 10:06 AM   #12 (permalink)
I get this every winter too. My driver side sprayer doesnt work, but my passenger sprays fine. So I would think that rules out a frozen line, but after the engine warms up, it sprays. So I am at a loss. Maybe one of the lines contracts and pinches off the line until it warms up enough?
Grim281 is offline   Reply With Quote
Heated windshield washer fluid? stealth Inside and Out 26 02-21-2011 02:24 AM
Kinked Windshield washer fluid hose Jonny2001 Mechanical Problems & Technical Chat 8 12-03-2010 07:31 PM
washer fluid spray while on the highway Grim281 Mechanical Problems & Technical Chat 3 04-14-2009 10:28 AM
windshield washer fluid mito Garage 26 01-20-2008 11:55 PM
Windshield washer fluid leakage DUB2CRS Mechanical Problems & Technical Chat 1 07-04-2007 03:27 AM
