Rust on the door - 8th Generation Honda Civic Forum
Old 12-07-2009, 02:25 PM   #1 (permalink)
Rust on the door
Going out to get some lunch I notice on the door some rust. It is the seam inbetween the thin small metal piece holding the rubber part next to the door frame. Where the two parts are attached. The seam doesn't seem to be air tight. I noticed small bits of rust. I checked the other door on the way back in and there was rust on the same location.
Anyone else notice this?
On a car that isn't even 3yrs old this shouldn't be happening. Mine is a 2007 Si bought in march of 2007.
ronin is offline
Old 12-07-2009, 04:25 PM   #2 (permalink)
cheers007's Avatar
Can you take a picture and show us?
cheers007 is offline   Reply With Quote
Old 12-09-2009, 11:12 AM   #3 (permalink)
I will take pics but I don't know if the macro mode on the camera is good enough to capture what I am talking about. At least people will know what location I am talking about and check on their cars.
This reminded me of that rust problem with the Toyotas. It might not be a big issue now but could develop into a bigger problem for anyone keeping their car for more then a few years.
ronin is offline   Reply With Quote
Old 12-09-2009, 06:10 PM   #4 (permalink)
cheers007's Avatar
If you can just take a picture of the rust (macro) and a large shot of the general area, then I can tell you how serious it might be.
Old 12-09-2009, 06:16 PM   #5 (permalink)
grmachine's Avatar
Steve
Rust is terrible stuff... no matter what you do (short of replacing the rusted panel or part altogether) it will never go away and will continue to spread, regardless of what vehicle you're driving.
OP... are you in Canada or somewhere that they use salt on the roads in the winter? This is a major cause of rust on Canadian cars.
I always recommend getting rust-proofing done regularly and clean the car (including the undercarriage) regularly. This helps prevent rust, but won't fix it unfortunately.
grmachine is offline   Reply With Quote
Old 12-09-2009, 06:25 PM   #6 (permalink)
ziwang55's Avatar
zi wang
rust proofing? the black stuff they spray under ur car?
ziwang55 is offline   Reply With Quote
Old 12-27-2009, 08:57 PM   #7 (permalink)
It took a while but here are the photos. On the second photo the lip area that is glued/welded? on is circled. The other two photos on the bottom point out the problem areas.
Old 12-27-2009, 09:00 PM   #8 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
I wouldn't worry about it. Thats just dirt.
FijiBlueFG2HT is offline   Reply With Quote
Old 12-27-2009, 09:34 PM   #9 (permalink)
I've seen it up closer then those pics and it isn't dirt that is for sure.
Old 12-28-2009, 09:46 AM   #10 (permalink)
Live by SI's Avatar
Peter
This is a problem area for our cars, something that is just starting to come to light now that they are getting to be 3-4 years old.
I would highly suggest that anyone living in the salt belt or state/ province that receives snow or even if you keep your car outside, have a look at the area where the OP indicates and have oil treatment applied if necessary.
Follow the lining all the way down and under the door itself with a good flashlight.
Live by SI is offline   Reply With Quote
Old 12-29-2009, 02:30 AM   #11 (permalink)
yuning83's Avatar
maybe you can claybar them out.
yuning83 is offline   Reply With Quote
Old 12-29-2009, 01:12 PM   #12 (permalink)
What type of oil are you talking about?
You must be kidding. This isn't a mere surface defect that can be claybared away. This points to a bigger problem.
Also, anyone know if this can be reported to a government agency for investigation? I'd talk to Honda of America if their customer service wasn't such a joke. Also, the same for the stealerships.
Old 12-31-2009, 02:24 PM   #13 (permalink)
cheers007's Avatar
I'm going to check this on my car as well. but honestly, it doesn't seem to be something very serious in my opinion (no flaming please).
Old 12-31-2009, 02:25 PM   #14 (permalink)
Mitch [Ryan #3]
Its just overspray.
Old 12-31-2009, 04:38 PM   #15 (permalink)
ziwang55's Avatar
zi wang
i live in MN. and all i get is salt and snow and dirty. so wtf am i suppose to do? i do get a car wash like every two days. cuz i got unlimited car wash membership thing.
Old 12-31-2009, 04:48 PM   #16 (permalink)
soysauce0894's Avatar
Billy
^ thats wat i do, on all three cars we own.
during these seasons i car wash them at least 2 times a week, just using water to risne as much off.
soysauce0894 is offline   Reply With Quote
Old 12-31-2009, 09:02 PM   #17 (permalink)
CivicEX08's Avatar
Stephen
I just checked my door and I'm seeing the same thing. I'm going to be bringing this to my dealerships attention when they replace my fog lamps because even though it seems minor; it doesn't seem right.
CivicEX08 is offline   Reply With Quote
Old 01-30-2010, 12:48 AM   #18 (permalink)
T-R
I'm surprised that I'm not seeing more posts on this.
My '07 has the same issue as described in OP and I wish that's all I had.
Unfortunately, I have a huge rust problem (paint bubbling up) under the rubber gasket right at the top of the corner (the 90 degree corner of the glass frame). And it's on both sides.
I already have 75K miles, so I doubt the rust warranty will cover it.
I'm hoping to fix it myself in the spring because every time I give my car to the body shop, something is F'd up when it comes back.
T-R is offline   Reply With Quote
Old 01-30-2010, 02:10 AM   #19 (permalink)
06CivEXJon's Avatar
J
The rubber weatherstripping on the drivers side door (bottom inside) is deteriorating. Anyone else have this problem? and the rust thing i have it too but it's not as bad and it's the same as yours. Nothing to worry about unless it's really bad and bubbling.
Old 03-03-2010, 02:38 AM   #20 (permalink)
oldskool's Avatar
I have it to. Anyone in Canada have this problem? I have an 07 Si.
oldskool is offline   Reply With Quote
Is it Rust?? Bubbling in top of door frame beside b-pillar trim turboawd Civic Coupe And Sedan 29 01-08-2012 07:03 PM
Door sill thread to end all door sills threads! Yospeed Inside and Out 850 06-24-2011 12:17 PM
Rust? Already? SilverSedanDJVG Mechanical Problems & Technical Chat 15 01-01-2011 07:51 PM
Warning: Rust! Rust! Rust! Whocares05050 Civic SI 149 10-05-2010 10:08 PM
