Closed Thread
LinkBack (9) Thread Tools Display Modes
Old 11-08-2006, 08:34 AM   1 links from elsewhere to this Post. Click to view. #21 (permalink)
06blaksi's Avatar
Originally Posted by ryryninja
quick question.. did you just use the stock hardware for the install. I know that people were talking about buying hose clamps from the hardware store because the ones that came with didn't fit.
Originally Posted by 06blaksi
I found a DIY for an R18 but not a K20 so here goes
First thing you need to do before you even start is go to the hardware store and pick up some clamps for the hoses that Injen supplies. Your existing clamps (which they tell you to use) don't fit.
06blaksi is offline
Old 11-08-2006, 12:40 PM   #22 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
oops... my fault.. i knew i read it somewhere before... hahahah i didnt know it was this DIY. thanks though... heres a good question.. is there an approximate size clamp that I should buy.... or do they all come the same ?
|108K Miles|I beat my tires harder than i beat my meat
ryryninja is offline
Old 11-08-2006, 12:45 PM   #23 (permalink)
06blaksi's Avatar
Sorry, I wasn't paying attention to size. I think I got the clamps that go from 3/8 to 5/8 and one from 1/2 to 3/4 I took the 3 hoses with me to Home Depot and just tried them. The ones Injen supplies for the intake tube are fine. You just need them for the 3 smaller hoses they supply
06blaksi is offline
Old 11-08-2006, 01:00 PM   #24 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
alright cool.. thanks again for the great DIY!
Old 11-08-2006, 03:48 PM   #25 (permalink)
SlammDizzle.
Mikey6p's Avatar
Mukey
Why do you have to replace the coolant lines?
Originally Posted by firmhonda
Sometimes, when I hit that "delete" button, I fap uncontrollably. When I'm done I dress as a king and force my girlfriend of 6 years to start calling me "Master" while making some of the lesser people in my neighborhood rub my face with velvet while feeding me delicacies from all over the world from a crystal bowl engraved with the numbers of all the posts I've deleted within the last 36 hours. It's a fine life indeed.
Mikey6p is online now
Old 11-08-2006, 03:57 PM   #26 (permalink)
06blaksi's Avatar
There's one hose supplied that's a different length from the stock one. The stock also uses hard lines which are removed. The coolant line runs from the TB to the thermostat housing
06blaksi is offline
Old 11-19-2006, 12:46 PM   #27 (permalink)
06blaksi, how did you remove the tabs on the fender trim (so you can remove the bumper)? do you just take them out with your fingers?
junsu is offline
Old 11-19-2006, 01:03 PM   #28 (permalink)
06blaksi's Avatar
I used a srewdriver and ended up breaking one of them but this was alos my 5th time taking the bumper off so it was bound to happen sooner or later.
06blaksi is offline
Old 01-11-2007, 09:24 AM   #29 (permalink)
[IVI]'s Avatar
Bryan
Is it advisable to have a cup handy when taking off the coolant lines so that any leftover coolant in the lines can spill into it instead of going all over the car?
Also, do you need to jack up the front of the car to remove the bumper or can you get to everything without getting underneath the car?
[IVI] is offline
Old 01-11-2007, 09:37 AM   #30 (permalink)
Mattzilla's Avatar
Matt
I'm sure it's possible to not jack up the car, but it certainly wouldn't be making the job any easier.
IIRC there's nowhere to fit a cup. Just keep some rags handy and stuff them all around where it will leak out, and you'll be fine.
Mattzilla is offline
Old 01-30-2007, 11:14 PM   #31 (permalink)
Seemund's Avatar
I took the bumper once to install the JDM H Emblem :) and today my Injen CAI arrived.. looks like I'm going to take it off tomorrow again :)
Seemund is offline
Old 02-01-2007, 02:07 PM   #32 (permalink)
Seemund's Avatar
help :)
I'm installing the Injen CAI, but I was taking the lines off, and now i'm confused..!! don't know what goes where.. lol
Seemund is offline
Old 02-01-2007, 02:19 PM   #33 (permalink)
06blaksi's Avatar
Originally Posted by Seemund
help :)
See the top thick hose coming from the valve cover towards the back of the motor? This goes to the top port on the intake
The next smaller hose about 6 inches infront of the last one on the valve cover goes to the lower intake port.
The third if you look where the black intake boot is you will see it right where it bends. This is the coolant line follow the route in the pic to see where it goes...hard to describe in words here. Hope this helps
06blaksi is offline
Old 02-01-2007, 02:20 PM   #34 (permalink)
Seemund's Avatar
thanks, just printed it :)
Seemund is offline
Old 02-25-2007, 04:32 AM   #35 (permalink)
Installed today along with Hondata img, went ahead and bypassed tb coolant with the injen supplied hose. What a difference, this is a good mod. Was a little pissed when I had to cut the inner fender guards. There is no way any one can run the intake without cutting the inner guards. I read some people got away with it...yeah ok. Anyways Injen CAI kicks ass.
Skin441 is offline
Old 02-26-2007, 03:39 AM   #36 (permalink)
Nexx's Avatar
Sticky?
Nexx is offline
Old 02-26-2007, 12:40 PM   #37 (permalink)
thoughtshewas18's Avatar
Garrett
haha why are you guys taking the bumper off?? I installed it easy without taking the bumper off you just take the wheel off (easier imo) and remove the plastic covering inside. Takes 2 minutes instead of 10+.
thoughtshewas18 is offline
Old 02-26-2007, 01:29 PM   #38 (permalink)
06blaksi's Avatar
By the time you jack the car up and take off the wheel, I can have the bumper off. It's been off 8 times for various shit. I can remove it in 2 minutes or less :)
06blaksi is offline
Old 02-26-2007, 01:54 PM   #39 (permalink)
Garrett
I guess if you want to keep removing the bumper thats fine lol.. I was just sayin I would rather just take off the wheel instead. Either way! :)
Old 03-08-2007, 06:17 AM   #40 (permalink)
I installed my intake today but when i got to the hoses i didnt have my directions so i went here to look for the info but there were no pics. Can anyone post the pics again? Thanks yall
Si_13.5s_oneday is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/18536-diy-injen-cai-install-si.html
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-27-2008 12:18 AM
2006 2007 2008 Honda Civic Si Parts-Header Exhaust Intake Shifter HIDs This thread Refback 02-12-2008 02:38 AM
DIY * Injen CAI install * Si - Page 11 - 8th Generation Honda Civic Forum This thread Refback 01-31-2008 04:02 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 09:17 AM
I'm noob with car shit so if anyone wants to drop a few pointers... - ClubCivic.com - Honda Civic Forum This thread Refback 12-31-2007 10:03 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 03:59 AM
DIY * Injen CAI install * Si - Page 21 - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 12:39 AM
Just Bought an Injen CAI - ClubSi This thread Refback 12-08-2007 06:28 PM
Just Bought an Injen CAI - ClubSi This thread Refback 12-06-2007 07:48 PM
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 92 11-11-2008 08:57 PM
Can someone please make a DIY installing an Injen CAI For the SI type-si Do It Yourself Articles 3 06-29-2008 02:02 AM
Injen CAI DIY???? vicSi Do It Yourself Articles 9 03-24-2008 08:38 PM
Injen CAI vs AEM CAI Review....hesitation etc. sickyute Bolt-Ons And All-Motor 118 10-07-2007 09:40 AM
Injen CAI install question... Toxis Do It Yourself Articles 9 10-18-2006 01:40 AM
