Intermittent A/C ?
Hey guys.. I have an 06 Civic Coupe EX and I've noticed the A/C doesn't seem to be working like it should. I've read over the A/C condenser sticky, and not sure if that's my problem.
Here's the issue. Whenever I'm at stop lights or driving slowly through a parking lot or drive through, my AC blows out hot air. When I'm driving at stable speeds around 35 or so, the AC runs fine.. and it's an icebox at highway speeds. Now I live in Texas.. so I'm sure that doesnt help much.. but this is obviously HOT air coming out of my AC when idling and what not.. it's cooler to roll down the windows. Any ideas? It's about $125 just to take it in and have them run diagnostic on it, so I'd like to have some ideas of what to expect? |
Jason
I have a similar problem.. except it turns on and off intermittently at a stop and even while driving. Every 2-3 secs it turns on and off (blowing ambient air).
Any ideas? (sorry don't mean to thread jack). |
Robert
OP, it sounds like your fans aren't running like they should be. At hgihway speeds you've got plenty of air running across your condenser, but at a stop, those fans should kick on to blow air across your condenser. I would start there.
#14 (permalink) |
A/C compressor clutch is replaceable.
Ensure both cooling fans (radiator and condenser) fans operate when you turn the A/C on. Since your A/C is an "icebox at highway speeds," then your A/C compressor clutch would be fine unless you have an intermittently faulty A/C compressor clutch relay causing the A/C compressor clutch to engage and then disengage intermittently (when the A/C is on). But, based on your vehicle's symptoms, I'd start with the cooling fans. |
#15 (permalink) |
If your cooling fans operate normal , take it to the dealer so they can monitor a/c pressures at an idle . I have had Bad a/c compressors that work fine off idle but will not maintain normal operating pressures at an idle . The dealer should also check refrigerant levels during this performance test .
#16 (permalink) |
I went to go drive it around a little bit, and noticed that the two fans up front intemittently turn off/on at idle. It's a noticeable fluctuation between the system having air pushed through with them on and it simply sucking up ambient air with them off.
Another thing, the car shakes quite a bit when the fans shut on and off.. it feels like there's a lot of pressure.. lol?? Is the shaking the compressor turning off/on? Isn't there any way to just keep the fans turned on while I sit idled? It doesn't make sense for them to want to turn off when it's 100+ outside.. (air is still coming through the vents when the fans shut off, it's not nearly as cold.. and it's usually hot) I can't seem to pinpoint the issue when idling and parked.. sometimes the fans stay kicked on, other times they fluctuate off and on.. other times they just stay off.. but pretty much anything 35mph+ is cold.. |
#17 (permalink) |
the fans will only come on when the system calls for it. it sounds like the fans are fine. I dont think you have a major issue. if it is the clutch you will here clicking when it engages and disengages. the fans will kick on when it meets the system requirements I dont know what the requirements are though. It would run off of refrigerant pressure or temp I would think. but the clutch should stay engaged when the ac is turned on all the time
#19 (permalink) |
hmm.. I don't know if it's that simple.. it's actually both.
Yes, they both spin when they are spinning. But, No they don't always spin when the A/C is on. Mind you, the A/C is always on.. and when it is, the fans turn off and on intermittently, or "cycle" as others on the forum call it. Should those 2 fans always be spinning when the A/C is on? Because, they dont.. |
#20 (permalink) |
Hmm.. well I've done a bit more digging.. but it seems as when the compressor cycles on and off, both fans also cycle on and off along with it. Is this normal?
I'm gonna take a wild guess that if I could get my fans to keep spinning at idle (instead of cycling off and on with the compressor), this might be able to increase the cooling at idle? Would it be possible or reasonable to install an additional electric fan with a control switch to help compensate for the current setup? Or maybe I could wire something to keep the existing fans on constantly, instead of shutting off with the compressor? I've seen and heard of people with different vehicles use electric fans and swear by them.. what do you guys think? Flex-a-lite Electric Engine Cooling Fans |
| Intermittent Hard Starting | Steve in CT | Mechanical Problems & Technical Chat | 21 | 05-21-2010 05:26 PM |
| Wiper intermittent | role model | Mechanical Problems & Technical Chat | 23 | 08-25-2009 09:37 AM |
| Intermittent Grinding Noise | BS_4banger | Mechanical Problems & Technical Chat | 1 | 06-29-2009 07:50 PM |
| intermittent wipers | fox | Inside and Out | 6 | 03-31-2008 04:43 PM |
| Wat do intermittent wipers do? | Domo* | Mechanical Problems & Technical Chat | 13 | 03-16-2007 09:28 PM |
